Question about Toshiba Satellite A100-S8111TD Notebook
Usb port not functioning
After installing new windows xp installation, the usb ports refused to work
  • Robert Cisco Jan 31, 2009
    I have windows xp sp2 but usb ports are not functioning.
Windows XP is not compatible with USB 2.0 ports. Could you confirm you have Service pack 2 or 3 installed. If not, you should install SP2, so they should work.
Posted on Jan 12, 2009
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
The USB Ports on my ACER TravelMate 2350 Series Laptop, I have deleted the USB Port files from Device Manager and the machine reinstalled them when I re-started but it didn't change anything. I downloaded...
I'm guessing your USB ports don't work or does it always ask you to install them. If you have your Windows XP license key at hand, please try downloading and installing the following...
Acer TravelMate 2350 XP Chipset Driver
Reboot. It might ask you to do a reactivation, or not.
Please recheck if your USB ports still work. If not, restart your machine, hit F8 continously until you get many options - choose the option "Safe mode" and press Enter. Check if it picks up USB in this Safe mode.
What you can also try, is that you have 3 different USB 2.0 ports on your machine. Try each one separately and see if one of them works. I would also recommend to see if the USB device you are trying to use is actually functional.
May 19, 2010 | Acer TravelMate 2300 Notebook
Printer only works on one USB port
You can swap thye ports areound on Vista, but Xp is more difficult. What happens is the USB is converted to an LPT port like lpt1 or 2. This remains in the device manager list because it is usally a fairly permanent object. USB printers are rarely totally USB, like other items. So windows fails to recognise the printer on other ports or, it will require a new installation for that port. With Vista you can go into Device manager and reassign a USB port to a printer port. XP is another ball game you might not want to play in.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 18, 2009 | HP Deskjet 5740 InkJet Printer
Windows XP Pro USB HID problem.
First suggestion is to shut down, change ports and then, upon reboot, wait a few minutes to let XP resolve the 'new' USB devices.
Second suggestion is to download and install the manufacturers drivers and then try switching ports.
Final suggestion is to use the port that works. i.e. I went to the doctor and said "It hurts when I do this". He replied "Well, then don't do that.".
Good luck
p.s. you may want to list the model of the keyboard if you would like a more specific response.
Sep 09, 2009 | Computers & Internet
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
AOPen O35g to usb port
sometimes adapters do not work.
this might work
start computer without mouse. you may have to work with keyboard tab key as you press tab key you should see the icons highlighted install drivers plug in mouse to usb if lucky O/S will recognize mouse and setup
Jul 17, 2008 | AOpen (O35G)
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
