Question about Sewing Machines
Thread jams & wheel axel cannot turn
Euro-Pro 911... Was sewing fine for an hour, then jams. Bobbin thread gets wrapped around the bobbin case after about 4 strokes of the needle. I have tried everything I can think of to fix it...changed needle, cleaned all components. This also happens when I manually turn the handwheel, with no fabric...after 3-4 strokes of the needle, the bobbin thread gets ''hung up'' around the bobbin case & the needle cannot move. I've checked & triple checked that the bobbin case is inserted properly. I am new to sewing & this makes me want to SCREAM!!! Please help!
Tara
  • 22 Answers
There are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
Why was it sewing fine then just stopped and seemed jammed?
It's likely that somewhere there is thread wrapped around a part. That can happen, for instance, during winding a bobbin without your noticing. Thread can also be wrapped around underneath the bobbin basket (holds the bobbin case). You may have to remove a cover to locate it. You didn't mention what model your machine is, but it would be helpful to purchase a service manual for it. It will at least tell you how to remove a cover to locate the problem. They are available at Service Parts Online; if your model is not listed, you can send an email, and chances are they can purchase it for you.
Apr 27, 2015 | Singer Sewing Machines
Thread is getting stuck around bobbin case in lower part of machine after 3 stiches. I have take the whole assembly apart several times and put it back together with no luck solving the problem.
Try turning your bobbin around, it may be facing the wrong way and it will get caught around the bobbin casing. I had that problem until I turned it around, just the bobbin in the case not the case.
Feb 18, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
I have a euro- pro model 385x. Every time I try to sew, the needle jams and the bobbin is surrounded by thread. I have tried loosening the bobbin as well as tightening it but to no avail. I get a big...
The problem is likely the threading. Double check the threading, look twice or three times at the diagram. Even me, a tech sometimes threads a machine or serger wrong.
Derek
Jan 17, 2011 | Euro-Pro 473
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Aug 16, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Aug 28, 2008 | Sewing Machines
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
698 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
