Motherboard Search I am trying to buy a motherboard for my laptop online. How do I know which motherboard to choose that would work as a replacement on my Acer Aspire 1820PT notebook. Which information do I get off my motherboard to look for the match online.
  • 7,627 Answers
This software may help:http://www.filehippo.com/download_speccy/ It will give the specs of your machine.Good Luck
Posted on Dec 07, 2012
  • Frank Mesak Dec 07, 2012
    Thanks Max for the referral to filehippo. I downloaded the software and it worked like a charm. Wish I could run that on my Acer while it was still working.
  • max carson
    max carson Dec 07, 2012
    I don't know if this helps, as you know, their are many different model and configurations http://acer.custhelp.com/app/pre_ask_lau...
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
Somebody pls help me i need driver for ACER-Aspire-3680-Notebook-Atheros-3945abg-Wireless-Lan-Driver-v10.6.0.29-Windows-xp
tq
Posted on Nov 21, 2008
  • 7 Answers
SOURCE: Acer aspire 3680 won't turn on / Black out.
This line of Acer laptop has numerous power issues. If the laptop actually will not power you will likely need to perform some component level repairs. If it powers on but does not complete POST. (Meaning you dont see anything on the screen) Then you would want to begin by removing the center panel on the bottom case. Once removed locate your memory sticks and make sure that they are seated properly. Remove them and reseat them. Try to power the laptop again and see if your problem is solved. It is possible that if this does not work that the memory is actually bad and must be replaced. There are quite a few other things that can cause this. Memory is the easiest to repair. This failure can be caused by a defective CPU as well, but for the average computer user I would not suggest taking your PC completely apart. If you are comfortable doing so you will want to disassemble it, remove the logic board and use a test CPU to see if this solves your problem.
In case your unit actually doesn't power on it changes things. The first thing you need to check is the status of your AC adapter. If you do not have a voltage meter you would need to use a test adapter to elimiate that possibility. More likely the problem is caused by an internally broken DC connector. This happens very frequently and is a rather simple repair if you posses decent soldering skills. You can purchase one of these DC connectors from ebay for $2 or so. Disassemble the laptop, remove the two screws that attatch the DC board tp the main board. Desolder the DC connector and replace it with the new one. Sometimes this DC board will have been damaged from a power surge. In this case the entire power plane connected to the back pin of the DC connector will likely be shorted to ground. If this happens remove the old DC connector, cut off the back pin and solder and heavy gauge wire directly to the back pin. Run this wire around the DC board on the left side of the DC connected as you are looking at the connector fromthe front. On the other side of the DC board you will see 2 farite beads wired in parallel. They connect the shorted power plane to the next. Remove these two farite beads and run the wire to the contacts on the next power plane. This will bypass the damage to the DC board.
If the DC connector is the the cause for the problem. There is a pair of capacitors on the logic board that fail very often. To see them you will need to remove the heatsink assembly from the logic board. They are ceramic capacitors right next to the CPU socket. They are wired in parallel and may bot show any physical signs of damage. If you have a multimeter set it to test continuity and put both leads on eachside of the caps, if you hear a constant beep then the caps register as shorted. Remove them both from the logic board and repeat this process with them outside the circuit. If you touch the leads to each side of the caps and hear nothing, then the cap is good. If you hear the same continuous beep then the cap is shorted and is the cause for your power issues.
If these suggestions have not solved your issue, then the motherboard may still be repairable but will require an experianced technician to isolate the cause for the no power. Good luck.
Posted on Aug 02, 2009
vishnu369
  • 94 Answers
SOURCE: where can buy Acer 4520 AMD motherboard
Firstly before replacing the motherboard please check whether the battery is working perfectly. I dont beilve its the problem of the motherboard and even if its the case other than battery it would be CMOS battery trouble . So check that stuff before directly going for the motherboard replacement
Thank u
Please rate me as it wil cost u just one click
Dont find a fault, find a remedy-Henry Ford
Posted on Oct 26, 2009
  • 85 Answers
SOURCE: hi can anyone tell me where the motherboard fuse
My understanding is there is no fuse to replace like you think. There is a fusible link soldered into the mother board that will have to be replaced if that's the issue.
Posted on Jan 28, 2010
Sony vaio vpcf115fm no display
Did You Checked The Conection betwhen your Motherboard and Display ?Did you correctly connect it? Try opening the bezel at top of the keyboard, in the zone of the power button, and try to locate the cable and move it, if the connection seems okey, it is possibly that you need to replace the entire cable
Jan 24, 2014 | Sony Computers & Internet
Hi, I'm looking for a replacement motherboard for
I'd advise against getting a replacement motherboard for a laptop. Though it may sound convenient in some situations, it's often a better financial choice to buy a new laptop (and swap the HDD over, if need be). In addition to it being expensive, it's a real pain to locate them, as you've noticed. Not to mention, you'll probably encounter many compatibility issues unless you manage to buy the exact same motherboard.
If you insist, though, the place to find replacement motherboards for laptops is definitely eBay. I don't know if you've checked there yet, but if you haven't, that's where you'll probably see the most of them. Worst case scenario, I would find the same model with a broken screen or something, and then swap out the motherboard.
In any case, good luck, whatever option you should choose.
Sep 25, 2013 | Lenovo ThinkPad T500 (20827YU) PC Notebook
I have this toshiba satellite p205D-s7436 laptop which is not working due to motherboard failure.should i replace the motherboard or buy a new laptop?please reply.
A new replacement motherboard will cost about $200, the labor to install it at a repair shop (a complicated job that requires plenty of experience) another $100, depending on the country you live in.
So you have to choose between spending $300 on an old laptop or $500 on a new better one. I would chose the second.
Jul 21, 2011 | Computers & Internet
I need replace or repair for my acer aspire 5571 motherboard
You can always get replacement motherboards for your unit. Simply get the motherboard model number from your current motherboard and search for it online. Best places to order from are amazon.com and ebay.com they are totally secure and guarantee to provide the best. Repairing motherboards usually gives no guarantee.
Hope this solution has been helpful?
Jul 17, 2011 | Acer Aspire 5500 5570-2609 Laptop
I need to buy a motherboard for hp dv5 1270BR. I would like to know the part number, manufacturer and where to buy. Thank you!
If you are trying to replace a non-working motherboard, try E-Bay. Search by the computer model number. You also will find the board with version number on the old board.
May 10, 2011 | HP (5185-6477) Motherboard
My HP pavillion laptop just shut down. I've been told a need to buy a new motherboard. ¿Where can I buy one at a reasonable price?
You might find a "used" one via eBay, but will it work?
Instead, access http://support.hp.com and get a genuine HP replacement part, and then find an HP-authorized technician to disassemble your laptop, remove the motherboard, install the replacement, and "test" the computer.
Jan 13, 2010 | HP Computers & Internet
Would it make sense to search for a replacement motherboard for my Acer Aspire 5610-4182 laptop, or just buy a new computer? I spilled wine on the thing, and 2 techies have told me the motherboard is...
Personally, I would search for a motherboard, and replace it. If you choose not to replace the motherboard, but buy a new notebook, send the notebook to me (freight COD), and I'll repair it.
Email me at buffalonymann@yahoo.com if you will send the notebook to me
Sep 15, 2009 | Acer Computers & Internet
Need a motherboard for Toshiba Satellite A105-S4004
A105 motherboards are available on EBay
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&catref=C6&from=R40&satitle=+Satellite+A105+motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2&fgtp=
At least one of those looked like an entire bottom plastic assembly.
Unless you are pretty computer savvy, you'll want a computer pro to replace teh motherboard.
Sep 09, 2008 | Dell Latitude D600 Notebook
D600 latitude motherboard
I recommend Ebay. You can get a good used motherboard for around $100, just make sure that the motherboard is guaranteed to work, so your protected if it doesn't. I've gotten many used boards off Ebay, and had no problems. Used or refurbished is just fine, there's really no sense in paying the $400 for a new one. If the $150 refurbished has at least one year warranty or better, that would be the route to go. Here's a link to Ebay's listing for the D600 motherboards. If you need assistance in changing out the board let me know.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37.l1313&satitle=dell+d600+motherboard&category0=
Aug 27, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
