Question about Proscan Televison & Video
Need code for proscan lcd tv PLCD5085A for direct tv remote
Need code for direct tv remote. Seems proscan has very few codes at all.
  • 86 Answers
SOURCE: Need DirecTV remote code for Proscan 26LB30QD
Direct TV Remote Codes for various devices.
Posted on Feb 15, 2009
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
SOURCE: lcd 32" proscan need code for universal remote
The code for Proton works for Proscan LCD televisions. I have 2 codes for Proton 10178 and10466.
Posted on May 30, 2009
  • 3 Answers
SOURCE: Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Posted on Nov 20, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I need the code for a universal remote to work with my Proscan tv
Your universal remote has a code search feature you can use to search for an appropriate code for your Proscan TV. If a thorough search through all codes stored in the remote fails, you may have to try another universal remote.
Mar 07, 2015 | Proscan 42LA45H 42 in. LCD TV
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Cant control tv with direct tv remote
Dec 27, 2008 | Proscan Televison & Video
Remote Code
evelchuckjr,
I came here looking to find out how to program my direct TV remove without any luck. The codes that direct TV provided are 10047 and 11447 for proscan. What code does dish provide?
Thom
Dec 06, 2007 | Proscan 26LA30Q 26 in. LCD Television
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
