Question about Dryers
Duet dryer won't turn on. has power from outlet. but dryer has nothing . No lights . Nothing. Nada . Zip . Zilch.
No more details than above.
    President:
  • 1,922 Answers
Remove the front door and screws securing the door to the front cover,then remove front cover and look for the thermal cutoff fuse as if this is open it will kill all power to unit,it should be on the blower wheel housing
Posted on Dec 07, 2012
  • 23 Answers
SOURCE: whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Posted on Jan 27, 2008
Ranglo
  • 1194 Answers
SOURCE: My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Posted on Jan 01, 2011
rickead1
  • 1998 Answers
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Posted on Jul 04, 2011
TheMobilian
  • 8220 Answers
SOURCE: My Estate dryer won't turn on. I push the on
See if the lever on the door switch clicks. You cannot hear a click or the lever is missing that could be the problem. On the backsides of the dryer is a dust cover. Remove it and look for reasons why the duct fuse might melt and kill power to the door switch.
See the lever there? That must be in for the door circuit to activate the motor.
Manual and more HERE
Posted on Sep 08, 2011
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool duet dryer won't heat,
Hello, welcome to FixYa.
I'll start by saying your post indicates it is obviously a Whirlpool "duet" dryer, I also understand it is not heating, however your post does not include a model number.
Since there are many differences from one model to the next that can cause a scenario where it won't heat (even within the Whirlpool line) If you can reply with the model number I should be able to assist you going forward.
I'll need to watch for your reply before going forward. Thank you.
Regards,
Macmarkus :)
Posted on Sep 09, 2011
Whirlpool duet dryer, no lights on panel...
check both breakers one may be bad if its a220dryer
Jul 24, 2013 | Dryers
Whirlpool duet sport dryer will not power on no lights nothing
check inside, white fuse should be near air flow . also near themo couplers, take volt meter ,place on continutee, first unplug unit. remove one ,of the two wire's. check to make sure circutt is closed ... if not rplace fuse.
Sep 15, 2012 | Whirlpool 279818 4Way Vent Kit for Duet...
Whirlpool dryer duet... the control lock light is on and the dryer won't work
this is the car and truck section - you may want to repost this in the dryer section
Aug 28, 2012 | Cars & Trucks
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Buell blast won't start
You have a bad switch somewhere - either the clutch switch in the clutch lever or the kickstand switch is bad. Of course I had a blast that had a sloppy connector at the back of the key switch that did all of the above too.
Apr 03, 2012 | 2001 Buell Blast
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
My PC is haunted or has narcolepsy!
it's probably over-heating you might think about getting a laptop cooler this usually sorts this kind of problem
Oct 17, 2008 | Computers & Internet
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
