Question about Microsoft Xbox 360 Elite Console
No IP address when connecting to dsl. Repeating problem
Toshiba TecraM4, xp. Have had this problem before and computer repair had me format hardrive.Worked for a while but started again.I have trouble connecting to wireless and to DSL. My other toshiba (which I am using now) connects fine with no problem.I have checked the services, but cannot see anything that is disabled that would stop computer from obtaining an IP address.
  • 47 Answers
It is possible that the network card is not working correctly without Windows warning of this.
try once again the ipconfig command (that's to get a new ip address) and see what happens.
Posted on Jan 12, 2009
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
My Toshiba Satellite Pro U400 has stopped connecting to the internet. Connectivity docotr says IP address needs to be set/was not set properly. Not my internet connection because other computer in the...
Your Toshiba Satellite Pro might be using a specified IP address. Try to set it to obtain an IP automatically. Depending on the Windows OS, whether it is XP, Vista or Windows 7, go to your Control Panel then Network connections or Network Sharing Center and double click on the Local Area Network connection (if your are using wired) or Wireless Connection. Look for the TCP/IP protocol and make sure it is enabled as "Obtain IP address Automatically" and "Obtain DNS addresses automatically". Then click OK to save settings.
Should you need further assistance, please let me know. Thank you for using FixYa.
Jan 31, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
I have an aptiva desktop and i need an ip address in order for my internet to work
But do you have any internet connection??if yes and if its DSL than ur dsl router will automatically provide ip to ur pc???
Sep 08, 2010 | IBM Aptiva E 572 (2174572) PC Desktop
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
How to enable ics in windows xp? what changes we hava to do in dsl properties?
You need firewall functions enabled, then go to Connections -> DSL -> Properties -> Advanced and check the box "Internet connection sharing".
You will need another network from which the connections come, that will be routed through the DSL connection. Select this network in the drop down box just below. I expect it will be something like, "LAN Connection #1" or such.
The other machines shall have to be configured to have the DSL'ed PC as gateway. In the LOCAL network connection properties of the DSL'ed PC, check the IP address assigned to it. Then in all the other PC's local conn properties, put the DSL'ed PC IP address as gateway.
Oct 30, 2009 | Microsoft Windows XP Professional
Hello My problem is that I have A Toshiba Satellite A100 model laptop. I have formated it and install windows XP Professional in it. It install successfully and it also find network adapter 1394...
The devices that have a yellow ? against indicated that device drivers was not installed.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
May 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Cannot share connection
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
Mar 22, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Can't connect to internet using DSL
Open My computer, then My network places. Then open View network connections. Your connection should say "Local area connection". Right click it and make sure it's set to "Enabled". Then Right click it then select repair.
Nov 08, 2007 | Toshiba Satellite 1805-S253 Notebook
Microsoft Xbox 360 Elite Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
