Question about Frigidaire ATF6000ES Front Load Washer
Getting E360 spins fine and then shut off five second later
  • Official Brand Answer
  • 4,342 Answers
Hello wdquintana - Are you certain the error code is E360? This manufacturer does not have any E360 error code for any front load washer or other units. They do have error code EB3, EF6 or EA3 however. I understand that it spins fine, however shuts off a few second later. In this case the washer could be experiencing a communication error with the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to see if it will display another error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Posted on Dec 12, 2012
No fast spin at end of cycle
You may have burned up the motor's starter windings. About the time it eases up to speed, the motor overheats, and shuts off. Five or so minutes later, the overheat switch resets and it attempts to start the spin cycle over.
Jun 02, 2015 | Washing Machines
Cpu fan error, but spins
hi,, there may be an problem faulty in motherboard,, or processor,,,
Sep 28, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
1996 Camaro won't start
My 94 z28 Camaro misfires whne shes hot, I got her on a diagnostic and they told me that the distributor {optispark unit} was reading faulty and that I needed to replace this before they could go further $1100 quoted, ye right, I bought one for new at $169, they quoted me $400 just for the unit, anyway, I havent installed it yet, Found out that backfiring could also be a module, well I have the dizzy now so I may as well get the module as well. Will let you know. I went to start my car today, it started briefly then died, I thought the dizzy had completely died. Checked fuses and connectors, It cranked over but wouldn't fire. Decided to surf for info on the net. 1 hour later I went back out and tried again, It fired up and ran, Must have had a gremlin, all seems to be back where it was now, Summary, go make some lunch and come back to it, nothing to lose except some time. {If still fails, check Air flow sensor, may be clogged}
Mar 25, 2009 | 1996 Chevrolet Camaro
Power to Amp but no lights and does not switch on
(1)When the unit is switched on the relay clicks in,but no sign of life, and then five seconds later the second relay clicks on/off don't know which. This symptom is DC outputted to speaker terminals. Check any DC at power amp stage output.(2)Must have blown up.
Positive. If Caps blew, your amp shutted itself down within 5 seconds due to + & - power supply creating an unbalanced +B & - B voltage not allowing your amp to turn on.
Oct 05, 2017 | Optimus STA-3500 Receiver
Cycle Signal Volume
Try this, with power off press spin for five seconds on and five seconds off until 88 appears in the display. After this either it will start with a c1 or it will flash an error code, write down the code and within five seconds press spin again to advance so auto diagnostics will start, if your display is bad F 2 will pop up quickly. Let me know, SearsTechToo
Oct 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Five second delay with pump
check the intake of the pump. It may be clogged with sludge or debris.
Oct 02, 2008 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
I turn my tv on with my laptop connected and the tv keeps shutting back off about five seconds later
It may be a VGS port issue of your TV otherwise Configuretion of your graphics card.
Please check it out and let me know
T.Boopathy
Aug 08, 2008 | Panasonic Televison & Video
Frigidaire ATF6000ES Front Load Washer Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
