Question about Crosley CDE6000 Electric Dryer
I have a Crosley dryer and I need to know the size of overheat protector for model number CDE22B7BC. The dryer had a faulty overheat protector as I had it checked by a serviceman but he thinks it may need a larger protector than he had. can you help?
  • Crosley Master
  • 8,220 Answers
The electric heater fuse takes a 300 degree limit. Pink dotI have a Crosley dryer - 6885cfc.jpgThe kit comes with a 250 degree for gas and a 300 for electric. many people have told me either one would work and many folks have said when the 300 degree poped they have used the 250 till it too dies.Keep the dryer clear of lint and regularly checked for lint balls and striped blowers to keep this problem at bay.
Posted on Jan 13, 2009
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Diagram for a crosley dryer model #COG9500W
Hello - From my research it is showing that it is an invalid dryer model number. In order for me to further assist you and provide you the most accurate information; may I please have the exact model number?
Nov 30, 2012 | Crosley Dryers
Where is heating element in crosley clothes dryer
What is the model number of the unit?
Nov 05, 2012 | Crosley Dryers
IM looking for a manual for a model cah4205awj
Hello jojothunder3,
I understand that you need a manual for your Crosley washer dryer the only place that I could locate the manual is Sears Parts Direct and you have to call to see if it is available at this number (800) 252-1698 the part number is #2206690 and is called a use and care manual.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Crosley CWDH11W Front Load Washer / Dryer
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
Just Stopped Working
Use a putty knife and press against those spring clips holding down the top.f23fbc9.jpg
Check the door switch for continuity. Let me know.
May 08, 2008 | Crosley CDE6000 Electric Dryer
Crosley dryer-model # cde6500w
I believe that you probably purchased a kit of fuses which provides fuses for several different types of dryers. That way the parts store can sell you the kit without knowing exactly what type of dryer you have. If I am right about this, there is no yellow fuse in your dryer, you will need to buy a new one to replace the red dot fuse. Also, you will want to find out what is causing it to blow again so quickly, probably your exhaust duct is a little plugged, causing the inside chamber to get too hot.
Dec 27, 2007 | Dryers
Crosley CDE6000 Electric Dryer Logo
69 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
