Question about JVC Cybercam GR-DVL805 Mini DV Digital Camcorder
Will not play back
I get a picture while recording. Screen indicates that the camera is recording. When I rewind to play back, tape rewinds, but when play is pressed, nothing happens. The tape is moving forward (I have to rewind again), but no picture on the screen, or when I hook up to my computer. HELP! I'm going on vacation Monday night, wouold LOVE to know how to fix this hopefully simple problem!
  • 38 Answers
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Posted on Aug 12, 2007
Playback problems
Could be dirty heads. Was the tape recorded on this camera?? Did u rewind the tape to the start??
Oct 01, 2016 | Video Cameras
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Nov 07, 2014 | Sony Handycam DCR-TRV740 Digital Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Has error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all JVC Cybercam GR-DVL805 Mini DV Digital Camcorder Questions
JVC Cybercam GR-DVL805 Mini DV Digital Camcorder Logo
121 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
