Question about HP Laserjet Pro 400 Mfp M425dn Multifunction Laser Printer
Can't set default paper tray - HP Laserjet Pro 400 Mfp M425dn Multifunction Laser Printer
5 Suggested Answers
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
POCBM
  • 121 Answers
SOURCE: settings in HP Printer LJ 4100.
The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper.
Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal.
The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2.
The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
Or the arms on the tray that operate the switches are not moving properly.
You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps.
Posted on Mar 28, 2009
the_fire
  • 432 Answers
SOURCE: HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Posted on Apr 13, 2009
vinay229229
  • 1121 Answers
SOURCE: Changing Paper trays on HP2430dtn printer
Press menu button, scroll to tray behavior, in that select type of paper, default tray & paper size etc..
Posted on Feb 02, 2012
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
Xerox Phaser 5500 will only print if started in the manual tray.
Check your printer setup/default settings on the printer. Make sure you are using the right paper in the trays and that they are set properly to the proper paper tray & size. You have to have it right in all locations for it to work right, or it will default to by-pass tray. 1st in the settings, 2nd in the trays, and 3rd in your printer software. Good Luck!!
Jun 07, 2012 | Xerox Phaser 5500 Laser Printer
Even though my printer settings are set to print and use the paper in tray 1 - the printer wants to pull from the bypass tray (which always pulls crooked). The printer used to work just fine then the alert...
Two things to check for a problem like this:
1) Driver Settings:
If your computer's drivers are telling the machine to pull from the bypass tray it'll ignore the machine settings. You're kind of on your own here figuring it out, if you can't though then try deleting the printer from the computer and re-installing it (will default settings)
2) Manual Feed sensor:
When you put paper into the bypass try you're activating a flag which tells a sensor there's paper there, if this flag is stuck forcing the sensor to constantly think you have paper there it would always to pull from there. Find the flag, move it back and forth, hit it with some air from a can of air.
May 31, 2011 | Ricoh AficioSP C222DN Laser Printer
How to make default tray 2 in HP Laserjet p3005n printer
HP printers will default to the highest numbered tray that contains plain letter paper. So on a standard 3005 Tray 2 is the default unless you have the paper type set for something other than plain letter. If you have an additional tray, then Tray 3 would become the default tray if it is set to plain paper. In this case, you would set tray 3 to either bond or letterhead so that the printer would only grab from that tray if you request either tray 3 be used or create a job that calls for that type of paper.
If this does not sort it out, post back again with a complete description of the printer including number of trays, what is loaded in the trays and how they are set for both paper size and paper type. This information can be found by printing a configuration page. This is done by pressing the arrow key on the control panel until display reads information, press checkmark (green button) then use down arrow until Configuration page is displayed and then press checkmark again. Page will print that shows all the settings for the printer.
May 08, 2011 | HP LaserJet P3005n Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
HP Laserjet Pro 400 Mfp M425dn Multifunction Laser Printer Logo
289 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
