Need a CHALLENGE AIR COOLER AND HEATER Model 4250162 manual
Lost the manual and need one to find out hot to work the machine
4 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
fireman23
  • 6 Answers
SOURCE: Hot Air from the cooler
check the a/c unit. make sure you dont have any leaks around your system. sometimes when you have a small leak it will take time to lose out of system. but you may need to charge your unit up again. Also your compressor may be out of service. check and make sure compressor is running
Posted on Apr 01, 2009
co7196
  • 3433 Answers
SOURCE: water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
Posted on May 11, 2009
I have just bought a secondhand challenge 414/0038 and I cant find where you empty the water when using dehumidifier?? As you can guess I didn`t get any instructions with it
There is a rubber bung on the bottom of the back of the unit. You remove this bung and water will drain out.
However you should read the manual because most of the humidity is supposed to come out of the exhaust with the hot air. I'm not sure how this works but it's in the manual
Please find the manual you need here:
http://www.stator.me.uk/414-0021.pdf
This covers 414/0038 and 414/0021 Air Conditioning units by Challenge
May 24, 2015 | Dehumidifiers
How do use my mira-cool portable cooler/heater no instructions or manuals
My mira- cool blows out hot air when I turn on cooler, do I need to fill container with water in the back
Dec 21, 2014 | Heating & Cooling
Installed a new GE Water Heater 40 gal (Gas based) I have the set thermostat at position A. The problem I have is I get very hot water for 10 seconds and then the water gets cooler and cooler quickly. Even...
1) First of all, did you install yourself?
Did you connect hot and cold water pipes correctly.
If hot and cold are reversed, water heater will not work.
Look at markings on top of tank.
2) Is gas valve all the way open? Is valve handle parallel with gas line?
3) Is water heater in a closed closet when it cannot get air?
4) All gas combustion appliances need air supply and outdoor venting.
5) Next thing, is to add a comment with exact size and type of water heater as shown on label on side of tank.
I might be able to access manual for troubleshoot.
Read the manual cover to cover twice.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
6) All water heaters come with warranty.
Return water heater to Home Depot, or outlet store and get another one.
7) Read information how to install:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | General Electric Water Heaters
My 1995 honda heater is blowing cold air.it wont blow hot.i changed the heater control valve.what am i to do.
try back flushing your heater core find the 2 hoses to the heater and start the motor let it run for a bit feel the hoses 1 should get hot and 1 should be a little cooler the 1 that gets hot is the inlet and the cooler 1 is the outlet remove them after the motor has cooled down and use a garden hose to back flush the core flush water through the outlet you dont need to use high pressure if you do there is a chance the core can crack and leak.
Dec 30, 2010 | 1995 Honda Accord
Our Neptune only blows super hot air. Which may sound good but it is ruining the clothes. It will not blow cooler air at all. Seems like this problem started more than a month ago. Is there an easy fix...
Clean the lint out of all air passages including the exhaust hose to the outside. Wash the lint filter in hot water and detergent to clean away fabric softener deposits which block air flow. Make sure that nothing is obstructing the air intake for the machine. If the problem continues, the heater thermostat may need to be replaced. Hope this helps!
Jul 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The heater in my 2006 Dodge Grand Caravan only blows warm air while on low. If the dial is turned to high it blows cold air. What is the problem?
It sounds like the heater valve is not operating. Find the valve on the engine firewall passenger side and manually open the valve. Find it by following the 3/4 inch heater hose to the firewall where it is connected to the valve. Most likely the cable ( or vaccum hose)from the temperature dial to the valve needs replacing.
Dec 31, 2009 | 2006 Dodge Grand Caravan
Locate manual for a challenge air conditioning unit
Check out fixya .com for a manual of your choie.
Dec 17, 2009 | Heating & Cooling
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Blueway airconditioner/heater/humidifier
I purchased a Blueway Mod BL 168 cooler N12907 0041344 air cooler/humidifier today November 9th, Purchesed from Rezzies Betta Electrical Stocklands Mall 5 Breeze Parade Forster N.S.W
My son was the sales Person, he was very busy so we took the display model which was last one in stock, he was very6 busy and could not find the book for it, They all looked later and still could find the book, I need this before I can use it. Cant get Blueway Company up on the internet. Please help me out here, as its very hot and I cand use it Thank You so much
Heather Kirkby
Jun 14, 2008 | Humidifiers
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
