Question about Samsung UN40EH6000 - 40" Class 40" viewable 6000 - UN40EH6000FXZA
Samsung model un40eh6000fxza has had all parts replaced including the front panel and we still cannot turn the tv on. There is a 6-8 second lag before the tv reacts but no picture or sound
Is this a problem with this model. It is under warranty and they are giving us credit for a new tv but do we want the same model
  • 179 Answers
SOURCE: My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Posted on Dec 01, 2007
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
  • 8457 Answers
SOURCE: samsung tv clicking sound
It ur power supply board it have components,is dead could be anythings,Capacitors bulbging happen mostly only on DLP Tv bacauce the FTB transformer,give high voltage for projection.Tries thes websites for replacement power supply board.Shopjimmy.com,Tv Repair World.com,Partstore.com or Ebay.com.
Posted on Sep 26, 2009
  • 11 Answers
SOURCE: no picture, just sound, blown y buffer board twice1
a4.. there are 2 of them, upper and lower buffer boards.. they control the top and lower half of screen devided horizontally, i have had many run ins with these sets. and usually the buffer boards arent cheap.
they plug into the ysus( y sustain).. its possible your y sustain is blowing the buffer moduals because one of its i.c.'s under the heatsink has popped on ya.. effectively creating a short that blows the buffer boards.
remove the buffer boards, turn tv on... feel the 2 silver heat sinks on that y sustain( beware dont zap urself.. just the tip of your finger on the heatsinks)
you may find that one is cold and one is hot...if so, you need a new y sus and probably to replace the buffer boards the a4 upper and a4 lower.
If you get a new ysus.. plug the a4 upper and lowers into it, look at your picture.. if ur missing the top half the top buffer is blown or lower half the bottom buffer is blown. or..no picture they could both be blown..an easy way to tell if u have no picture to diagnose is..touch the heatsinks that sit over the chips on the buffers..if they are red hot.. they are bad and shorted internally.
Posted on Dec 11, 2009
UN40EH6000FXZA SCHEMATIC
Request the schematic diagram directly from Samsung.
May 06, 2017 | Samsung Televison & Video
Samsung UN65F9000AFXZA TV won't turn on until several minutes go by. Can you offer any suggestions?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 27, 2017 | Samsung Televison & Video
Repair advice for Samsung TS02
The TCON board or the LCD panel is faulty. can confirm by replacing TCON board.
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jun 01, 2016 | Samsung UN40EH6000 - 40" Class 40"...
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
How do I fix my Samsung 60" Plasma flat Screen TV
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 29, 2015 | Samsung Televison & Video
My SAMGUNG UN40EH6000FXZA wont turn on. Its 2 years old, no warrenty, can I fix it myself?
may need capacitors replaced. check for bulging caps in the power supply circuit
Mar 01, 2015 | Samsung Televison & Video
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Model #: LN40A450C1DXZC TV will not turn replace
Call Samsung Customer support. Some of these sets are being repaired on a one-time courtesy basis.
Oct 06, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
Sep 02, 2009 | Samsung TX-R3080WH 30" TV
Samsung syncmaster 914
You can have a look at THIS parts shop for switch board of your TV or mention the model number of your samsung TV to help you out.
Oct 02, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung UN40EH6000 - 40" Class  40" viewable  6000 - UN40EH6000FXZA Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
