Question about Symantec Computers & Internet
Bootable Floppy Though floppies hv become more or less extinct, i still want to know how to create a 'Bootable Floppy'. I seem to hv forgotten now but still like to know. Thanks. S.K.Tangri
  • 59 Answers
Go to this site for bootdisk download:
http://www.bootdisk.com/
Posted on Jan 12, 2009
Password reset asking foir insertion of floppy disc or usb flash drive#
You should have created a floppy-disk (or USB flash drive) after you initially defined the password, so that you can now use that device to "reset" the password.
Or, search for "Nordahl Offline Password" -- it's a bootable CD that can "blank" an existing password. Then, boot from the 'C:' drive, and leave the password field blank, and you will be able to login, and then set a more-memorable password, and you will be able to create that floppy-disk (or USB memory-stick).
Mar 07, 2014 | Lenovo Thinkpad 05K9283 - USB Portable...
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
Oct 19, 2011 | Computers & Internet
I forgotten my Adminpasswort!
I have 2 solutions, reset the BIOS by removing the CMOS battery or you can make a bootable USB or Floppy password resetter, if you wan't to know how to create one please chat me so that I can instruct you directly.
Oct 22, 2009 | Dell Inspiron 4100 Notebook
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
Boot cd problems
You can't just put the windows cd in your cd rom drive. If your going to change your boot order (to cd), then you HAVE TO use a BOOTABLE cd. That means a bootup disk with all the correct bootable files for WINXP. Same with a floppy. Change your boot order to a floppy....and in order to bootup windows, you MUST HAVE the bootable files ON THE floppy. In your case...the cd. The windows xp does not have the bootable files since it is only used for install and reinstall.
Create a bootable CD or floppy (((from someone elses WINXP pc or laptop))). There is a feature that allows you to do that. Then when you boot to cd it will start windows and give you options.
Mar 31, 2009 | Panasonic Toughbook CF-27 Notebook
More info please
the page I said before hp.com has software to make usb bootdisk from floppy ;also has floppy image if you cant find a floppy.
create new folder on desktop...
download hp usb boot to desktop...
download floppy image to new folder
make sure usb stick plugged in..
unpack/install hp usb boot ..
in the program
select device(usb stick
select quick format and create a dos startup disk.
"using dos system files located at" new folder...
click start..
thats ur usb bootable ...before you add any files you can try to see if it works cos sometimes you dont have to access bios it finds auto...worth a try seeing as the whole proccess of downloading installing and making usb bootable takes about 10 to 15 min...
if bios recognises device pc will start and you will see c:/ promt
of course this isnt a c:/prompt it just fools the bios .
if at first you see non system disk gtry press ctrl+alt+del and let start again (sometimes have to do this,bit like kickstart)
if you see the same error then obviosly bios needs to be told but if its recognised then add your files to the usb stick and away you go.
Jan 11, 2009 | Computers & Internet
Need to reset factory nec powermate as daughter has forgotten password as admin
You can reset by downloading a password restore iso file and creating a bootable CD from this if you have a CD writer on another computer. Otherwise check the NEC website on how to restore the original factory image (but you will lose all installed programs and user files).
Or use a friends PC to make a bootable floppy or CD.
http://www.loginrecovery.com you can make a bootable floppy disk or CD from this site.
Aug 08, 2008 | NEC Computers & Internet
Autoexec.bat
Format a floppy, in xp, set the "create an MSDOS startup disk" check box. copy the bios file & program to floppy then boot. follow mfr instructions. If it is an intel made board, download "Express BIOS" and run in windows.
Jun 05, 2008 | Intel Motherboard
N600C Bios Update
You can make a bootable cd of the flash image and update the bios that way.
Jan 20, 2008 | Compaq Evo N600c Notebook
Computers & Internet Logo
37 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
