Question about Panasonic TH37PX60 37 in. Plasma Television
Panasonic TH37PX60B led blinks 10 times doesn't power up
4 Suggested Answers
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
diodeic
  • 1622 Answers
SOURCE: My 50" panasonic only blinks 10 times but
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. See more bad capacitor image
Now, if your LCD set is still under warranty I would suggest to use it and let the professionals handle the problem for you. But for the rest of the Samsung LCD TV owners that their warranty had expired and want to save some money, this would be the best route. Mind me, when I fixed my power supply I didn't have any previous experience on desoldering and soldering capacitors on a power supply board. It was a good experience after all is said and done.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
I hope that this will help to solve the problem and do take care because it contains high voltages...
Posted on Aug 08, 2011
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
PANASONIC TH-50PX75U PLASMA TV LED LIGHT BLINKING 10 TIMES
That is a power suuply problem,i have the same problem i looking for a solution to fix my or i gonna buy a new one,also new onw is spensive on ebay some people offer the repair service good look
Sep 03, 2012 | Panasonic TH-50PX75U Plasma HDTV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a 42PFP5332 which doesn't turn on. When plugging in the power the green led on the power circuit board turn for a few seconds and then blinks for 9 times. After that it blinks for 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Philips 42PFP5332D 42 in. Plasma...
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Panasonic TH-42PZ80U doesn't turn on. 10 time blinks
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 27, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
Be prepared -
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic TH37PX60 37 in. Plasma Television Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
