Question about Sanyo Xacti VPC-T700 Digital Camera
My camera will not stay on
Yes my camera will not stay on my battery has been checked and that doesnt seem to be the problem . when i have it on the charger though it will stay on but this is no good for me when i am traveling..
  • 3 more comments
  • Anonymous Jan 30, 2009
    my camera will not stay on & the shutter does not close all the way???? I went to the batery store & bought a new battery, it still had the same problem????
  • Anonymous Feb 20, 2009
    My camra as well won't stay on when its not pluged in.
  • Anonymous Apr 14, 2009
    I have the same exact problem... should there be a recall??
  • Anonymous May 06, 2009
    I have exactly the same problem too, was working fine then tried it one day and thought the baterry was dead so charged it only to find out it woukdnt charge, but will work fine when plugged in. not sure what to do?any suggestions?
  • rossy65
    rossy65 May 11, 2010
    I believe that the AC adaptor may be faulty.   Check and if your AC adaptor is a VAR-G9 (look on the bottom of the AC adaptor).  Mine failed after only two days.  These units SHOULD NOT FAIL.
    You can get a equivalent replacment at Radio Shack, or other electronics supplier.  The Radio Shack unit that will replace the VAR-G9, is the P/N 273-1696 $32.00 US.  This unit has a switch that must be set to +5V.  Also there are assorted tips, and the +/- is IMPORTANT.  Make sure the + side of the adaptor is aligned with "TIP" as the TIP of the adaptor is positive on the VAR-G9.
    Plugging this in backwards will very likely damage your camera.
Batteries.
It is possible that the batteries you are using would work in another device, but not have enough amperage to keep your camera happy.
Buy some new rechargables- lithium ion (li-on), if you can afford them, or Nickel Metal Hydride- (Ni-MH).
Again, higher the amperage (measured in milli-amp hours- mAh- the better)
Posted on Jan 13, 2009
Place a small piece of paper on top of the battery and then slide the door closed on top of it. My replacement battery does not fit tightly enough to make contact without it.
Posted on Dec 22, 2010
What are other causes of a phone not turning on besides a dead battery, overheating, and freezing?
replace the battery for starters
check that the charger is putting out the correct voltage
Jun 05, 2017 | HTC HD Windows Phone 7
When i plug my charger into the camera, it stays red for 1 minute, and then continuesly flashes orange, and doesnt charge, anyway i can fix this?
The problem appears to be in the rechargeable battery itself, I would replace the battery but not until the old one is checked first at the camera store.
Jan 13, 2011 | Samsung Digimax L830 Digital Camera
Camera will not turn on
are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? if yes did you charged your battery? If yes try to check if the camera has blinking light on it while its charging? if doesnt have the light there might be a problem on the camera or may be the charger.
Now if has the light indicator thats a good sign., please clean the 3 metals contacts of KLIC-7001 then turn on the camera again., if this solutions did not solved the issue it means camera needs of service please kodak kodak Toll free 1 800 235 6325 for U.S and Canada support only
Oct 26, 2009 | Kodak Easyshare M753 Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
My camcorder doesnt charge up properly, ive purchased a new batteery and charges a bit but doesnt charge to full, light keeps flashing to say somethings wrong. I put it on the pc and it seems to charge.
Is the charging of the battery part of the camera or is it a separate charger? Meaning you remove the battery from the camera and install it into the charger to charge. Of course, if the charge is not full when both batteries have been on the charger, then the charger is at fault. Also, considering that you have also put a new battery on the same charger and the problem is still the same, then the charger is (again) at fault. You can try and send the charger to the retailer for inspection or, better still, take the whole camera and get it checked. Bad batteries or charger can cause more trouble to both the batteries or the camera.
Sep 18, 2009 | Samsung SC-DX103 DVD Camcorder
Will Not Charge
I recomend to buy a new charger original of the camera
May 16, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
RED LED BLINKING WHILE CHARGING THE BATTERY
It is normal. Just push both sides of the charger in. It happens all the time.even though it might stay blinking its normal
May 04, 2009 | Olympus FE-230 Digital Camera
Battery won't charge...
You can take you battery to a place called batteries plus they can check out to see if it is you battery if the battery is good than you have a bad charger. you can get one cheap off of ebay. They are 45.00 plus at batteries plus lots cheaper off ebay and some time you can get a charger and battery combo for half the cost of the charger from them. hope this helps.
Mar 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera wont stay on
No it is a switching issue and is not going to get better. Kodak technical support will tell you more be prepared though -if you have had this for some time then the next camera purchase looms I guess
Nov 06, 2006 | Kodak EasyShare V550 Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
197 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
