Question about Kenmore Washing Machines
Cleaning drain pump kenmore 4810
Where can I find and how can i clean the drain pump on a Kenmore front load washer 3.5
jsrock516
  • 5911 Answers
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
  • 949 Answers
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Posted on Apr 21, 2010
SOURCE: Kenmore 90 washer won't drain
How do I operate it? which program should i use for regular laundry?
Posted on Jul 08, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have the Kenmore front
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Posted on Aug 14, 2011
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
