Question about Dishwashers
Kitchen aide dish washer the door is sagging on one side. The hinge seems to be disconnected
  • Dishwashers Master
  • 17,115 Answers
If that is an under cabinet model, you need to pull it out of the position that it is in. The hinge pin is most likely damaged or broken. To pull it out, rermove the screws that are holding it to the counter top. Then slide it out
Posted on Dec 08, 2012
watugot
  • 290 Answers
SOURCE: broken door spring on kitchenaid dishwasher
The other end attaches to the frame. There is a row of notches, The further back in the row you attach the spring, the more tension there is on the door. I recommend replacing the springs on each side if one has broken, the other one is likely to fail in the near future.
You can get the parts from any whirlpool parts dealer or order from sears.com, or repairclinic.com.
Post back if you need further help.
Thanks, Mike
Posted on May 07, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 530 Answers
SOURCE: kitchen aid dishwasher not cleaning dishes well.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Posted on Oct 18, 2009
Testimonial: "THANKS SO MUCH. WE REALLY HATED WASHING THE DISHES BY HAND. THE CHOPPER HAD FALLEN OFF AND JUST NEEDED TO BE PUT BACK IN ITS PLACE."
SOURCE: washer won't start, power is ok, how do I check
no lights are on on the control panel
Posted on Jan 02, 2010
Refrigerator door sags and binds opposite hinge side. Can lower hinge be moved to raise sagging side?
Most likely cause is a worn cam in the hinge. After a while plastic cam wear out a causes doors to sag. Take your model number to Searspartsdirect.com and find the hinge cams and replace. Our went out a few years ago and our door did not shut. We came back 4 days later to a real smelly mess all over our kitchen thanks to these plastic cams. To prolong useful lifetime, try coating the cams with protroleum jelly. Doors should shut when you release the door when open 1 inch by themself. If they do not, the refrigerator feet need to adjusted so front is a little higher than back.
Sep 29, 2014 | Refrigerators
Washer door drops when i open it.when i close it i have to lift door. hinge seems loose
This may seem obvious, but tighten all the screws on the front panel, especially around the door hinge area. A #2 Phillips screwdriver is all you need. Also, try to see where it's dropping - is it at the door itself, or does the entire hinge assembly sag where it enters the washer?
Jun 21, 2014 | GE WCVH6260FWW
Oven door hinge weak right side
I am not an expert but I did have a spring break and had one disconnect on one side and that made the door sag on the one side Good Luck
Dec 13, 2012 | Kenmore 95592 / 95594 / 95595 / 95599...
I have a kenmore he4t washer and the front door
First thing to check is if your door hinge has a sag to it. The next step if there is a sag is try adusting the screws that hold the hinge on the frame of the door sometimes these do come loose. and do require tightening. Folowing confirmation that there is no sag in the hinge your next step would to order a new door latch. If you are not mechanically capable of removing the front section of the machine you should call a technician
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Drivers side door is sagging
you could try some door shims in the hinges
Jun 21, 2008 | 1990 Pontiac 6000
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
