Question about HP PSC 2355 All-In-One InkJet Printer
0xb9000009 error code 165:hw_interrupt_hwv2.c
2 Suggested Answers
  • 3 Answers
SOURCE: error 0xb9000009 165hw interrupt hwv2.c
Might also be dried out electrolytic capacitors on the printer circuit board. If you feel adventurous you can check this yourself by removing the plastic cover around the power / USB connectors and then blowing warm air onto the circuit board with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Replacing them is no task for beginners though...
Posted on Apr 01, 2011
H-400 error on Sharp 165
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
Radio error codeURC HW error
code URC HW error: HW usually stands for hardware which means some part of the electronics has failed. Without a model number I can't look up the code "URC" but I'd suggest you do a search on the web for "Motorola model ##### error codes"
Oct 25, 2013 | Motorola Radio Communications
I am facing F2-04 error code in sharp AR-M 165
# - interrupt- C - Interrupt -press 16 press Print key then machine is ready.
Feb 12, 2010 | Office Equipment & Supplies
The same
youre showing a hardware interrupt code for the printer... check with HP on the specific by mfg website
Sep 14, 2009 | HP PSC 2355 All-In-One InkJet Printer
Dish washer displays pf code
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Jul 18, 2009 | LG Dishwashers
Error code OE
The error is DE - DRAIN ERROR , Not fully drained out in spite of 5 min. drain operation
Possible causes
¥ The Filter clogged.
¥ The Drain Hose kinked or blocked.
¥ The Drain Pump/Motor or circuit is troubled.
Possible solutions
¥ Clean the Filter.
¥ Remove the cause of kink or block.
¥ Replace the Drain Pump/Motor or repair the Circuit.
Jul 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
HP PSC 2355 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
