I bought a 30'' philips tv in 2004 costing £1,999.99. Within a short time I got the screen...
(More)
I bought a 30'' philips tv in 2004 costing £1,999.99. Within a short time I got the screen divided into three parts. After begging the retailer I finally had a call from an engineer who said it was faulty and under gurantee. It was too big to get into his car so said he would call back. It was eventually collected and I ordered a replacement. I took the cost of the fist off the balance and sent retailer a settlement cheque which was accepted. Later I was sent a demand for the money. I do not have the TV set. 15 mths ago I was told I would not be bothered again. Suddenly last month I was issued a claim by Bryan Carter. I am counterclaiming against them. It was described as an LCD TV and was not HD ready.? How many other people have been cheated like this? I will never buy anything philips again - ever.
I have a Phillips 30PF9946D TV. The video drops out in response to sudden high input such as a...
(More)
I have a Phillips 30PF9946D TV. The video drops out in response to sudden high input such as a flash in the program content. Any ideas if it is correctable or just relates to the video buffers?
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the...
(More)
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the exact same problem and TV as you, and I fixed mine by leaning it forward. I think there may be a leveling safety feature for the screen, and it gets out of wack. So maybe try leaning it back and forward until you find the sweet spot.
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent...
(More)
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
