Question about Frigidaire FDL25P1 Dehumidifier
Changing filters for lad704dul
How do you change the filter on the Frigidaire Dehumidifier Lad704dul?
5 Suggested Answers
  • 4736 Answers
SOURCE: We have a Frigidaire 70
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Posted on Jun 27, 2011
I had the same problem with the LAD 704 DUL......I tilted the unit back just a little bit. The water is now flowing through the hose and into my drain....
Posted on Jul 03, 2011
  • 4736 Answers
SOURCE: My model is Frig. Dehumidifier,
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Posted on Jul 10, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have c
    If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
    If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
    A few things that can cause this are:
    The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
    The compressor has failed...if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
    If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
    If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
    If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
    If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
    Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
    There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 - 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
    As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
    Posted on Aug 14, 2012
    Changing the filter on a Frigidaire dehumidifier model no. FFAD5033R10
    Hello Paul, thank you for your post!
    From my understanding you need help changing the filter on your Frigidaire dehumidifier. I have located a copy of the manual and on page nine it will provide you with proper instructions on how to remove the filter. Best of luck! -Matt
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Edison/66129917125en.pdf
    Apr 06, 2016 | Frigidaire Dehumidifiers
    How do I change the filter on my dehumidifier lad704tdl
    The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
    For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
    I hope this helps.
    Mar 09, 2015 | Dehumidifiers
    I have a LAD704DUL frigidaire dehumidifier that will not shut off after being shut off, and not until the plug is pulled. Is this worth getting fixed
    Dear Peter Nicolle,
    according to the user manual the dehumidifier will not stop running for the following 5 reasons:
    • Windows or doors near dehumidifier are open to outdoors.
    • Area to be dehumidified is too large.
    • Air movement through dehumidifier is blocked.
    • Dehumidifier has been installed or restarted recently.
    • Dehumidifier is in the CONTINUOUS mode.
    You can find more information on the user manual on page 9 under the category DEHUMIDIFIER RUNS TOO MUCH.
    http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
    Nov 30, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
    Good Afternoon Friend,
    I understand that there is no water coming out of your Frigidaire dehumidifier, model# FDF50S1. I also see that the filter is fine and the fan is running. If you have your dehumidifier set up to continuously drain through a garden hose, make sure there are no kinks or clogs in the garden hose. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
    Jun 20, 2014 | Frigidaire Dehumidifiers
    Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
    Hello Friend, thank you for your question!
    I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
    May 15, 2014 | Frigidaire Dehumidifiers
    I cant change humidity levels
    Hi Ra Ma,
    After you have set the desired humidity, the readout will display the actual room humidity. It has a built in hygrometer which will be on the display while it is running.
    You change it and it shows the actual levels.
    See page 5 on manual.
    http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
    Mar 02, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
    I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have...
    Aug 10, 2012 | Frigidaire 70-Pint 2-Speed Dehumidifier...
    I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
    Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
    The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
    Hope this helps you to solve the problem.
    Jul 20, 2011 | Frigidaire Dehumidifiers
    My model is Frig. Dehumidifier, 70 pint. model # LAD704DUL. I hooked up the hose for continuous operation, but the bucket fills up too, even though water is definitely coming out of the hose. It...
    Jul 10, 2011 | Frigidaire Dehumidifiers
    Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
    Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
    To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
    Hope this helped you. Please let me know. Thanks.
    Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
    Dehumidifiers Logo
    29 people viewed this question
    Top Frigidaire Dehumidifiers Experts
    Lawrence Oravetz
    mike cooper
    Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
