Question about Ruud Heating & Cooling
I need a heat exchanger for ruud m# urka-a036jk10e
NEED HEAT EXCHANGER
4 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: Ruud UBHC-17AOONFA heat exchanger
Instead of air , it uses water to extract heat and send it thru the tubings.
Posted on Sep 04, 2008
SOURCE: leaking from secondary heat exchanger
Hi cgcol
I just had the same problem with the same boiler and was recommended to get in touch with a company called Wolseley uk. http://www.wolseley.co.uk/servlet/reality/rscp/IN.BRADETFRMBP1?app=centers&ses=99999|47543&website=www.wolseley.co.uk
link is to their website branch locator. You need to click on parts center on the left hand side of your screen under branch locator, then put your post code in as easy as 123. The parts you need are o rings. They come as a set, their part number for the set is 459382 FROLI 39817620 ORING SET as shown on my invoice. Only cost £7.19 + VAT. Plus bought 798007 REGIN REGZ40 SILICONE GREASE 50G cost £5.47 + VAT (smallest size they do). This is to lube Orings before fitting and pushing pipes together. Make sure you have turned all stop taps off that are under the boiler and drained rads.
Hope this has been a help!
Posted on Jan 09, 2010
  • 8 Answers
SOURCE: i need a wiring diagram for a ruud urka-a036jk10e
There's a wiring diagram inside the high voltage section glued on the inside panel (that you have to take off to access).
Posted on Nov 19, 2010
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Where is the heat exchange in a rheem pool heater located ?
The PVC plumbing is hooked into the front header, the front header is attached to the heat exchanger. The heat exchanger looks like copper finned tubes with a steel plate on each end. You need to disassemble heater working from top down to get to the exchanger. A skilled tech can replace an exchanger in under one hour service call.
Aug 19, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Leaking heat exchanger
balance chemicals in pool and replace heat exchange
Jan 08, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I need a wiring diagram for a ruud urka-a036jk10e
Aug 26, 2010 | Ruud UAKA037 Air Conditioner
I have a Ruud AC DATE: 12/00 Model:
Here is a tip about trouble shooting your air conditioner...
I would check the air filter and the blower motor...
sounds like a problen with one of them...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 20, 2010 | Ruud Heating & Cooling
Hi - I have a RUUD system, the heat won't come on
sounds like the "Fan/Limit" switch. It is to turn on the fan as the heat exchanger warms up. I believe it has failed. Check it out.
Hope this helps.
Feb 15, 2010 | Ruud UBHC Air Conditioner
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
I have a Pentair MiniMax NT heater about three years old. The unit is making a loud "popping" sound when heating. I think its the heat exchanger from what I am hearing. Can a heat exchanger be cleaned out?...
the heat exchanger can be reamed or replaced but it is quite a job; replacing the heat exchanger is very expensive and time consuming. unless your pool chemicals are extremely out of balance, most especially low ph from using tablet chlorine or too much acid the heat exchanger should not have worn out this quickly. the best solution if you do not have a pool serviceman is to call Leslies Pool Supply or a trained Pentair service tech. It may be worth the service call to have the problem diagnosed by a pro.
Jun 24, 2009 | Pentair MINIMAX NT TSI IGNITER
Jul 11, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
