Question about HP DesignJet 2500cp InkJet Printer
How can i solve system error code 070104 085300E9 on hp dj 2500cp
2 Suggested Answers
brett207
  • 231 Answers
SOURCE: Designjet 2500cp error 010036 00000100
This can be caused by a faulty electronics module, trailing cables, printhead carriage assembly, or ANY of the stepper motors.
try this...
Switch the printer off from the back, and then disconnect the trailing cables from the electronics module.
Switch the printer back on.
If the error code changes to '010037'
If the error stays as 010036, change the Electronics Module.
If it is 010037, replace the trailing cables, then the carriage assembly.
Trailing Cable Part No. C4704-60015
Electronics module Part No. C4723-60114
Posted on Apr 30, 2010
How do I reset or replace ink cartridges for hp designjet 2500cp
if you deal with accredited ink supply shops you will not have that problem either on line or in a shop
accredited shops have phone numbers and addresses that you can check up on
Aug 09, 2016 | HP HEWC1806A - C1806A Ink
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Aug 13, 2014 | Office Equipment & Supplies
try this...
Apr 29, 2010 | HP DesignJet 2500cp InkJet Printer
Hello. You probably have a worn out trailing cable. The manual says:
System Error: 010036 (see next page for 010036 0000XX00)
Problem Description: ADC Test Failure in the Main PCA.
Corrective Action: Try the following:
 Switch the Printer OFF from the back and
then disconnect the Trailing Cable from the
Electronics Module. Switch the Printer ON and
see if the Error Code now changes to “010037”.
If the error code remains as “010036”, replace
the Electronics Module �� page 8-6.
 If the Error Code changes to “010037” then try
the following:
Make sure that the Trailing Cable is
connected correctly.
Replace the Trailing Cable �� page 8-36.
Replace the Carriage Assembly �� page 8-42.
The manual can be downloaded at: www.lpscomputer.com/ec/manuals.htm
Apr 28, 2010 | HP DesignJet 2500cp InkJet Printer
I am gettin a error 070104 055300E9
This is a firmware error. Possible causes are corrupt image file or defective firmware. Try other print files. If some work, then some are corruped. If none work, replace the firmware. Call 800-959-1575 for firmware.
Feb 08, 2010 | HP DesignJet 2500cp InkJet Printer
Installation problems with HP dj 460c drivers
unplug the printer then install the drivers then reboot the PC then plug in the USB printer to USB port then insert again the CD installer..if their is same the problem you need to re-install the OS/windows...good luck
May 27, 2009 | HP Deskjet 460c InkJet Printer
Printer head contact error.
no. sorry Rick but i think you really need to replace the carriage assembly, if you can find one. these printers are aged. hope this helped you.
Apr 26, 2009 | HP DesignJet 2500cp InkJet Printer
E-8310 error code, will not play discs and intermittenly will not eject.
This is a Traverse Assembly error. More than likely it will have to be replaced.
The part can be found here: Pioneer CDJ800MK2 Part
But I do not recommend self-repair for something like this.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 21, 2009 | Pioneer CDJ-800MK2 Turntable
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
Lost the drivier for HP Deskjet D2360 inkjet printer
Click on the link below to download the driver for the HP Deskjet D2360 for the windows vista operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-47558-1&lc=en&dlc=en&cc=us&product=1100995&os=2093&lang=en
Click on the link below to download the driver for HP Deskjet D2360 for the windows XP operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-41763-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=1100995
Click on the link below to download the driver for the HP Deskjet D2360 for the windows 2000 operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-41763-1&lc=en&dlc=en&cc=us&lang=en&os=181&product=1100995
Sep 21, 2007 | HP Deskjet D2360 InkJet Printer
HP DesignJet 2500cp InkJet Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
