Question about Xerox Office Equipment & Supplies
How do i clear fault code 012-270 on a xerox docucolor 250
  • 2072 Answers
SOURCE: docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Posted on Mar 12, 2008
SOURCE: xerox docucolor 250 error code 042-326
Belt Failure turn the mach. off and un plug for 20 to 30 seconds then turn back on if this dosent sole you need to call a tech to replace the main belt
Posted on May 30, 2009
57 varieties
  • 1653 Answers
SOURCE: xerox docucolor 3535 error 016-387
I've seen plenty of these issues with Fiery's connected to all manner of printers.
Actually, 016 errors are network related issues. The 387 usually indicate an issue with tthe switch device that the fiery is connected to and not the fiery itself. Get the connection from the fiery to the switch checked out and also the port status on the switch itself. Also recycle the Xerox and Fiery and you may also have to recycle the network switch as well.
Posted on Sep 14, 2009
SOURCE: Xerox DocuColor 1632 /2240 Enter the Diagnostics Mode
fuji xrox 2240 error code 102-372
Posted on Feb 15, 2010
SOURCE: xerox docucolor 12 system fault 15-362
I have the same problem, 15-362!The problem persist after i restart the machine again and again.Your solution its not working!something else?
Posted on May 24, 2010
Fault code 127-337
Xerox dc240 error code 127-337 problem solustion
Aug 06, 2012 | Xerox DocuColor 240 242 250 252 260 Black...
Fault 010-321 what does it mean
010-321 Fuser nip fail, usually after repair fuser unit, commonly we accidentally spoil the nip sensor.
May 21, 2012 | Xerox DocuColor 242-252-260 PS
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Black stain shadow from the same image print
a fault or an error has occurred see user guide for information on fault code 042-326  Docucolor 250
Mar 26, 2009 | Xerox DocuColor 12 Color Copier
3,723 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
