I have Siemens WM 2000 E. When using the hotwash cycle at 40 or 60 degrees the machine stops and two lights start blinking.
  • 15,935 Answers
The ECU is likely damaged in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
The soap powder in my washing machine is not getting dissolved. This is a front load A07-16 electronic model.
This will be due to one of three causes.
  1. You are using an incompatible wash powder for your machine. If you're in India (the WM A 0716 was an India-only model) then some of the cheapest domestic brands are really poor quality and some of the established major brands are counterfeit products.
  2. Most powders contain some insoluble components which should be rinsed out, so the rinse cycles are not working correctly. This can happen if the wash load is too big for the machine and fails to allow space for the rinse water to circulate, otherwise it's likely a machine fault.
  3. The wash cycle is too cold. You have either selected too low a temperature or the machine has a failed heating element.
If the machine is faulty then you will need to contact Siemens for repair.
Sep 17, 2010 | Siemens Washing Machines
How to get rid moldy smell in LG Front loader washmachine?
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
May 09, 2010 | LG WM-2277HW Front Load Washer
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Jan 06, 2009 | Washing Machines
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
299 people viewed this question
Top Washing Machines Experts
