Question about Kenmore 659 Electric Dryer
Drum not turning properly
Following the removal of sock stuck between door and drum edge indesit is60v appears to have lost its ability to turn drum when more than a kilo of clothes inside. PS. I did smell burning before removal of sock - believe wedged sock stopped drum from turning properly. will attempt to repair machine myself but would appreciate some guidance as to best staring point. Thanks. Dave
  • 979 Answers
Check the belt and see that it is not worn down, kind of like a fan belt on a car. You may want to replace it anyway. next, the motor be be loose from the frame it is fastened to. Feel the surface of the drum for any grooves or worn places. There may be build up of debris. You can take off top of dryer to gain easier access to the drum.
Posted on Jan 14, 2009
How do I repair indesit IS60v door latch
Get on the manufactures web site and contact them through customer support and they should be able to guide you through the process. The link is most likely at the bottom of the page.
Apr 27, 2014 | Indesit Is60v, Is60vexpai, Is60vnl Tumble...
Washer fills water, drum is stuck
you may have a sock stuck in between the drums
rotate the drum when it becomes stiff you stop then take out the lower paddle by pulling it
you may now see the sock
Dec 01, 2013 | Indesit W 123 Front Load Washer
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
My indesit is60v tumble dryer is clunking when it spinning and sounds like it got something stuck in it scrapping inside
More likely to be worn rear bearing, and or drum shaft,or possibly badly worn drum belt
To access the inside of the dryer,remove top cver and right hand side pane llooking from the front.
Jan 28, 2010 | Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
Hi, My Indesit is60v tumble dryer has developed a heating (or lack of) fault. I have replaced the heating element & stats. I notice that it only heats when the drum is going in one direction, when it...
yes it will heat in one direction the longer clockwise one... when it does its short reverse tumble it switches off... there is also a duct thermostat that could be causing the premature heat output but also check the vent pipe and hose for blockage plus door filter remove and look down the hole as build up could be hidden...
Dec 18, 2009 | Dryers
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Indesit is60v dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Nov 30, 2007 | Dryers
Kenmore 659 Electric Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
