Question about HP ProBook 4540s Notebook PC ENERGY STAR
Blue Screen Error
Computer blacks out and a blue screen with a error message appears. The computer restarts with a screen with the start up options. I usually choose the normal startup.
  • 2 more comments
  • Frank Mesak Dec 07, 2012
    I was just working while connected to the net. The error message mentions video adapter but I do not have the time to read properly before the screen changed.
  • max carson
    max carson Dec 07, 2012
    Have you updated a Graphics Adapter? Take a look at the link I posted. If it has only happened once, I would not be overly concerned.
  • max carson
    Take a look at this:http://h30434.www3.hp.com/t5/Notebook-Ha...
  • max carson
    Here's more than you want to read:http://www.google.com/webhp?source=searc...
  • HP Master
  • 7,627 Answers
What were you doing ,just prior to the shut down? Take a look at this:http://pcsupport.about.com/od/fixtheproblem/ht/stoperrors.htm
Posted on Dec 07, 2012
  • 3 more comments
    Thanks Max The site site helped understand the problem but not fix it
  • max carson
    It may be just a software glitch, it may never rear it's ugly head again, but then again?
    The problem occured about 3 times today.
    And 3 times yesyerday
  • max carson
    Is the laptop overheating? Getting sufficent air flow? Have you cleaned the fan and vents? Have you done a Memory Diagnostic? Did you notice, when you get the BSOD what the fault is? Have you changed/upgraded any hardware/software, BIOS, Registry Editor?
  • 287 Answers
SOURCE: zd8000 wont boot up
try to get into SAFE mode... tap F8 repeatedly when you first power on. You should get a safe mode boot menu, select last known good profile and press enter.
If this does not work reboot go into SAFE mode and select Safe Mode from menu and see if it will boot up.
You may get a pop up to use system restore, say yes, select restore to an earlier date (or similar) then use the calander to select a restore date that is PRIOR to the problem starting.
If this does not work boot to safe mode again and say NO (cancel) to use system restore and see if you can get to the desktop
post back results for further troubleshooting
Posted on Jul 16, 2008
crayzeetrayn
  • 837 Answers
SOURCE: HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Posted on Jan 14, 2009
frankzjm
  • 191 Answers
SOURCE: HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
Posted on May 14, 2009
heavymetal77
  • 721 Answers
SOURCE: Screen divided into 2 mirrored sections.
This sounds like a hard drive failure. You can press f8 to enter safe mode with networking during post. If it boots to windows,then go online & download the video driver from nvidia,install it & reboot. If that doesn't work,try re-formatting. If it won't do that then try a new hard drive. I have the software needed to test the hard drive,but it's for commercial use only. This is the back yard method.
Posted on Jul 15, 2009
SOURCE: error : 0x400110020000100A
Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
Posted on Nov 26, 2009
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Igxprd32 error
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 13, 2012 | Computers & Internet
Sir my pc has automatically restart and does not worked proprely they can give the fatal error plzz helpp me
Are you getting a Blue Screen error and can't read it because the computer keeps restarting?
If So, turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Scroll down past safe mode and you will see an option to Disable Automatic Restart. The next time you boot up you will be able to see the error message.
If it is a Blue Screen Of Death (BSOD) error message, you might need a system disc.
Mar 26, 2012 | Dell OptiPlex GX620 PC Desktop
My laptop won't go on properly just has a black screen & keeps rebooting
Sounds like you have the "blue screen of death" , BSOD, problem. You need to determine the error message so it can be fixed.
Restart your computer and hit F8 several times a second until you have a black and white scree with several options. One will be "turn off restart on error" Turn that off.
Now when you get the error you can see what the message is. Post it here for more help.
Oct 10, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Blue screen frequently appears, and it reboot by itself? pavillion g7-1070us
A blue screen often called Blue Screen Of Death, BSOD, indicates that something is wrong with the computer. Usually it is a driver that is not correct or corrupt.
You need to specifically identify that the BSOD message is. If the system reboots before you can read it, boot the system while hitting F8 many times per second until you see a black and white screen with a number of options. Towards the bottom will be one regarding automatic restart on error. Uncheck that option. Now the BSOD will stay on the screen and you can post the stop code here to get help.
I hope this helps. I do this for fun & feedback not $$$
Jim
Oct 05, 2011 | HP Pavilion dv9000z Notebook
Netbook turns on blue screen appears but doesn't give enough time to read what it says and then restarts continuously
Hi there!
You can follow this simple steps so that you can determine the exact blue screen error that you are getting.
Start the computer and keep pressing the F8 key. It will lead you to Windows Advanced Option Menu (see picture):
highlight Disable automatic restart on system failure and press the enter key. It will restart the computer and will stop on the blue screen error instead of restarting your computer.
Hope this helps.
Apr 21, 2011 | Acer Computers & Internet
Blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
When I turn on Dell Inspiration 1525 laptop. after 2 minute it appear blue screen error and then restart the system.
As soon as you see your "wallpaper" on the Windows desktop, click Start.
Point to My Computer.
Click with the SECOND (usually the RIGHT) mouse-button on My Computer.
Click Properties.
Click Advanced.
Below Startup and Recover, click Settings.
Click to remove Automatically Restart.
Click OK.
Now, the next time that you see the "Blue Screen Of Death", what message _stays_ on the screen? Write it down. On another computer, do a Google-search for that string, and read what others have done when they have gotten the same error-message.
Oct 22, 2009 | Dell Inspiron 1525 Notebook
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP ProBook 4540s Notebook PC ENERGY STAR Logo
242 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
