Question about GE Profile Harmony DPGT750GC Gas Dryer
GE profile dryer not drying completley
Got to run through 2 cycles to dry
  • whatafinish7 Feb 13, 2009
    I have a simulare problem, mine will not heat at all, this is the third time this has happen why??
  • 45 Answers
Check that the vent outside (especially in northern climates this time of the year). Then check the hose that goes from the drier to the outside vent. Finally, check the drier itself, that there is no obstructions getting to the hose. Check the lint trap. Is it full or is it installed properly? If all this checks out, then try replacing the heating element. These are usually inexpensive, and fairly easy to replace. The manual for the drier should have diagrams on how to access it.
Posted on Jan 12, 2009
Hello, I'm having problems with my dryer. I have a GE Profile Harmony Dryer and its not drying like it should, I have to run the cycle 4 or 5 times for it to get hot and dry the clothes... It also has...
The first thing to do is ensure that the outlet air vent is not clogged with lint, socks, or other obstructions. It may be clogged at a point outside the dryer, so you might have to move the dryer out of the way, then use a flashlight and mirror to look into the vent.
If it is not clogged, then the problem is likely the heating element or heat sensor.
Jul 13, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a GE profile dryer dpgt750 and it will not get hot only stay wsrm
you need to access the cycling switch and the sensors in the dryer heater/blower housing and possibly replace the drying sensor bars by the door on the unit
Oct 03, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer is taking 2-3 cycles to dry clothes most of the time, but last night it did two loads the first try and then is back to 2-3 cycles today.
Remove the connecting vent material from the rear of the dryer. Run a regular cycle. If it dries normally,find and clean the blockage in the connecting vent.
Aug 26, 2009 | GE Profile Prodigy DPSR513GA Dryer
GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Jun 19, 2009 | GE Profile Harmony DPGT750EC Electric...
DRYER PROBLEM
my dryer shut off one day and will not start up I reset the breaker switch and no luck
Oct 06, 2008 | GE Profile Harmony DPGT750EC Electric...
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
161 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
