Question about TP-LINK Computers & Internet
Leds meaning in router tp-link wr741
Leds meaning
cnavarro
  • 2460 Answers
SOURCE: TP LINK ROUTER SINAL PROBLEM
The range in free air is 100-150 feet with the original antenna. Since you have at least two walls of unknown composition and 30 feet minimum of space between buildings, it's unlikely. that a straight connection will work. You might consider a TP-Link access point and 2 larger antennas to send the signal farther.
http://www.tplink.com/products/product_des.asp?id=116
The antennas are at the bottom of this page:
http://www.tplink.com/products/wlan.asp
About $80 gets you the AP and a pair of antennas.
Carl
Posted on Apr 09, 2009
Geekman
  • 32281 Answers
SOURCE: TP LINK MODEN ROUTER ADSL2 PROBLEM
If the PPP LED is flashing all the time then you have not got a connection to your ISP's server.
Have you contacted your ISP?
The ISP can test the ADSL connection to the your ADSL2 modem and advise whether it is a fault or not..
Posted on Sep 17, 2009
  • 145 Answers
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you http://www.tp-link.com/support/showfaq.asp?id=151
Posted on Oct 17, 2009
govinda123
  • 2260 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
shademand
  • 114 Answers
SOURCE: I'm using TP-LINK TD-W8101G ADSL
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Posted on Sep 06, 2011
Tp link TL-WR740N router indicating orange light what to do?
Means no internet connection , better check the network connectivity properly.
Jul 15, 2016 | TP-LINK TL-WR740N Router
How i reset to factory defaults without passwords?
That depends upon the brand of the router. It would be wise to google for the particular brand.
There often are software means to perform a reset but here are the hardware means.
For Netgear:
  1. Press and hold the Wireless On/Off and WPS buttons until the Power LED blinks red (about 6 seconds).
  2. Release the Wireless On/Off and WPS buttons and wait for the router to reboot.
For Linksys:
1. Press the red reset button on the back.
2. Unplug it from power for 30 seconds. Plug the power back in.
For Belkin:
1. Find the reset button (depends on the model).
2. Depress the reset button for 15 seconds.
3. Wait one minute for the router to restart.
Here is a tutorial for Cisco routers:
http://www.networkworld.com/article/2343961/cisco-subnet/how-to-reset-a-cisco-router-to-factory-default--removing-the-startup-configuration-file.html
Here is one for TP-Link:
http://www.tp-link.us/article/?faqid=496
For D-Link:
Push a paperclip into the hole marked reset on the back and keep it depressed for 10 seconds.
The default user name is usually admin and there is no password (password is blank).
May 11, 2015 | Computers & Internet
Why do I have limited access on new tp link router TL-WR1042ND?
You would usually get this message when you have a faulty or weak connection to your router or internet, try checking your internet, and move your router away from dead spots(meaning areas with mass amounts of electronics like computers and tv), and move the router higher.
Jul 12, 2014 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
One of the lan led is continuously blinking
It means progress and activity, unless if it is un plugged.
Mar 03, 2014 | TP-LINK TL-WR642G Router
Tp-link tl-wr841n system light keeps on flashing, how do I fix it?
system light must flashing every second or one second . that is mean the system work correctely . but if the light was flashing rapidly , i think there is problem with system .
reset router , if the light keeps flashing , change the router
Aug 21, 2013 | TP-LINK TL-WR642G Router
TL-WR541G : i can't log to router and also do reset for it
Push and hold the reset button for 30 seconds or so, it's usually in the back of the device near the power AC jack. http://www.tp-link.com/en/support/download/?model=TL-WR541G&version=V7
Nov 28, 2012 | TP-LINK TL-WR541G Wireless Router
I has forget my pasward of my router. router MODLE is TP-WR740N
Then you're screwed.. Only one solution:
Use the Factory Default Reset button: With the Router powered on, use a pin to press and hold the Reset button (about 5 seconds) until the SYS LED becomes quick-flash from slow-flash. And then release the button and wait the Router to reboot to its factory
default settings.
Regards,
lb_service
Sep 18, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
Computers & Internet Logo
49 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
