Typewriter ribbon bunching - Office Equipment & Supplies
3 Suggested Answers
  • 3594 Answers
SOURCE: need black typewriter ribbon for Olympia typewriter
A General Ribbon T6 or equivelent will work.
DickyO
Posted on Apr 30, 2009
  • 3594 Answers
SOURCE: how to install typewriter ribbon on a Sears typewriter model no 2
I believe this T/W takes a Gen. Ribbon T5 or T7. Check to see which way the spool turns over 90% wrap to the outdide of the spool. Put it on to wrap in that direction, the ribbon will have an eyelet about 6" from the end be sure that is wrapped on the spool. From either side put the ribbon tru the reversing arm, tru the lifter, tru the other reversing arm and back to the other spool.
DickyO
Posted on Jan 19, 2010
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
Can you still buy ribbons for a olivetti 25
Yes!
Go to etsy.com or artfire.com and search for "typewriter ribbon" or "universal typewriter ribbon"
I got mine at http://www.etsy.com/shop/AtomicDreams and it works great on both my manual typewriters.
Ribbons are also available on fjaproducts.com , but the Etsy / Artfire peeps have cheaper shipping :)
Aug 20, 2010 | Olivetti Lettera 25 Typewriter
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Need black typewriter ribbon for Olympia typewriter
DickyO
Apr 27, 2009 | Office Equipment & Supplies
Typewriter just beeps
very common problem, The print wheel homing sensore weirs broke off. you need to take off the ribbon deck. pull weirs from the white plastic sleeve that runs from carrier to main board. fined 3 weirs grouped together ( red, black,green) 1 or more of them are cracked in side the casing or have broke in 1/2. need to resolder them together little tough to do the 1st time. a bunch of sen sores came out with to hard of a weir making them brake premacherly
Jan 08, 2009 | Nakajima AE-710 Typewriter
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Aug 08, 2008 | Swintec 7040 Typewriter
Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
May 22, 2008 | Brother Office Equipment & Supplies
Swintec 7040 typewriter ribbon feed.
The typewriter is supposed to automatically adjust itself to the type of ribbon you have installed. Have you tried a different ribbon?
Feb 11, 2008 | Swintec 7040 Typewriter
48 people viewed this question
jasbo
jasbo
