Question about Amana ASD 2624 Side by Side Refrigerator
Not getting cold
The problem I am having is: my freezer and fridge. is not getting cold. When I plug it in the compressor seems to work fine. I took off the back panel inside the freezer section, and the coal started to get frost on it, but the evaporator fan would not come on. Does this fan susposed to come on when the fridge. is first plugged in? or do I have another problem?
    President:
  • 1,462 Answers
Fan only comes on when evaporator is down to temp. the fact it is not coming on points to a compressor fault ie evap not getting cold enough
Posted on Jun 20, 2007
SOURCE:
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer cold but fridge warm
first leave it off for 24 hours, and then put it back in operation. if its doing it again , then chck the heating element, defrost timer...
Apr 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Running fine but blowing warm air
"it seems to work fine but will not get cold"
Not sure how it can work fine and is not cold. When you say work fine, is the light on and the freezer fan blowing but is the compressor running?
Unplug the Ref and wait about 30 min or so, plug it back in and listen for the compressor to start running. You should be behind the Ref to hear this. If you don't hear it start running then you may hear a clicking noise. This clicking is a problen with the compressor start relay. If the compressor runs but still is not cold then it could be low on coolant.
Dec 16, 2008 | Refrigerators
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Amana ASD 2624 Side by Side Refrigerator Logo
77 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
