Sharp 27C-240 27" TV
Problem for Sharp 27C-240 27" TV
Location
By bluesmoke_20 on Jan 12, 2009
where to find the horizontal section and does eletrolytic capacitor have specific markings
Best Solution
posted on Jan 12, 2009
Helpful)
pgh_pa_guy
Rank: Guru
Rating: 91%, 727 votes
Look for the horizontal output ("flyback") transformer, which has a red lead coming from it to a connection cap at the top of the picture tube. The horizontal section is that portion of the board. (There are other horizontal circuit parts on other areas, but most of the ones prone to failure are in the area of the flyback.)
Electrolytic capacitors have three important markings: the value (in microfarads, usually abbreviated MF or uF), a voltage rating, and a polarity (some brands mark the positive lead and others the negative, but there will be a polarity shown). If you replace a capacitor, stay with the same capacitance value, but consider a slightly higher voltage rating (but never lower). The replacement will be a little larger but likely would still fit, and under-rating is what causes most failures in the first place. Be sure to get the polarity correct when installing the new part.
Be careful working on your TV. Capacitors and the picture tube can store charges that can shock you even after the set's been off for a while.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp 27C-240 27" TV
Questions and Unsolved Problems for Sharp 27C-240 27" TV
Do you recommend Sharp 27C-240 27" TV?
Answer
Answer
tv wasn't getting cable channels.I used remote and randomly pressed numbers.Then on the screen it... (More)
Answer
no power up at all. fuse is good
Answer
no other problems just went out while watching
Answer
When my sharp Tv model 20AG1 - S was powered on only horizontal line of blue/red/yellow without... (More)
Answer
I used to be able to watch dvds on my tv using the input channel, but a power surge erased the... (More)
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
