Question about LG WM-2277HW Front Load Washer
Detergent drawer will not open
The drawer that you open and put detergent into, on my LG front loader washing maching, is jammed and will not open all the way to put the detergent in. Could someone please advise on how to fix this problem. Thank you in advance.
The soap dispenser in my LG WM2277H front loading washer keeps getting stuck shut. I have tried wiggling it, jiggling it and yelling at it. Nothing works. I can not pry open the back as suggested and drill a hole. There has to be a solution! Please?
Posted on Jul 07, 2010
  • 1,543 Answers
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Posted on Jan 12, 2009
My washer jumps around when spinning. this happens intermittently
if it is a front loader and on a pedestal make sure it is level not just front to back but side to side also. Here are some of the reasons a front loader shakes violently.
1-- not level
2-- unbalanced load... washing 1 item or large comforter
3-- Wrong soap.. using reg detergent instead of HE
4-- bolts mounting mach to pedestal are loose. They are located above the drawer. two for front and two for rear.
5-- Faulty shocks.. requires tech to repair
6-- unhooked springs.. requires tech to diag and repair
7-- rear bearing failure. can be checked by pushing up on top front edge of basket and looking for movement independent of outter tub. Sometimes you can feel a clicking of the bearing moving up and down when you do this. This repair usually costs more than the machine is worth if very old. Ignoring this problem can lead to more damage, water leakage, and possibly fire.
Sep 17, 2011 | LG Washing Machines
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Where do i out the laundry detergent, when there are two sections
Look closer at drawer that comes out. The labels for pre-wash and wash are under the lip on my LG. Stand to the side and look towards your hand that opened the detergent drawer.
May 12, 2009 | LG WM2487H Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
804 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
