Question about IBM System x3500 7977 - Quad-Core Xeon X5355 2.66 GHz (7977H2U) Server
Controller monitor failed,controller not started appeared on my screen when i opened our server systemx3500
I opened our server after having no power in the area for a day and this appeared on my screen.what does it mean
    Scholar:
  • 143 Answers
This is a raid controller failure. Server is not able to initialize device.
Workaround:
1: Turn off server
2: Take out Raid Controller from server > blow air on raid controller slot to remove dust.
3: Put it back
Now turn on server and see of it gets initialized.
If you still gets error then its time to replace controller
Thanks
Posted on Apr 10, 2014
ciscoroute
  • 87 Answers
SOURCE: ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Posted on Jul 07, 2009
SOURCE: Question: I have one server
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Posted on Dec 20, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: my os is windows 2003
did you ad the firm were first
Posted on Dec 24, 2010
SOURCE: Fatal error: controller monitor failed
Replace the flat cable on the motherboard of SAS1 to SAS2. Resolved.
Posted on Feb 26, 2011
  • 143 Answers
SOURCE: I have IBM Server x3400
Welcome to Fixya
The problem is with the raid controller . Either the controller is faulty or it is due to dust or happen some shake. To rectify this issue do the following
1: Switch off the server 2: Remove the Raid controller from the server and clean the dust . ( Please Don't touch with hand just blow air ) 3: Clean the Controller slot 4: Refix the Controller and power on the server . 5: Check whether the controller is booting or not . 6: If you gets same problem then replace the controller
Thanks
Posted on Mar 05, 2011
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Server beeps continuously can not read monitor ,keyboard
you should start by re-seating the RAM first as this is a common problem. if that does not work re-seat the processor. If all that fails remove all add on cards and memory only leaving the processor and see if the beep codes change. Replace the components one-by-one to find the problem piece of hardware. HERE is a guide from Dell to tell you what the beep codes mean and also some troubleshooting tips.
May 08, 2012 | Dell PowerEdge 2500 Server
Power off server > Take Raid Controller out > Clean Controller as well as controller slot > Insert it back
Power on server and check .
If you have same problem , then its a controller issue . You need to replace it .
Thanks
Mar 20, 2012 | IBM x3400 Server
I have IBM Server x3400 Tower . I got Error message Fatal error : Controller Monitor failed. Controller not started Press any key to continue
Welcome to Fixya
Thanks
Feb 14, 2011 | IBM x3400 Server
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
Dec 15, 2010 | IBM x3400 Server
Just recently the monitor started experiencing a faded screen and vertical lines1/8" spaced across the screen. A remote controller took over my computer and saw what i saw and mentioned something...
Greetings,
You can double check the suggestion of the vidoe card by connecting your computer to another monitor. If the lines appear on the second monitor then the diagnosis is correct and the video card in your computer is failing. If the lines do not appear in the second monitor, then your monitor's screen is failing and you'll need a new monitor.
Regards,
Selk
Nov 16, 2010 | Gateway HD2200 LCD Monitor
Fetal error controller monitor failed x3400 ibm server
Welcome to fixya
Open the server and take out the raid controller . Now clean the slot as well as the raid controller . Now replug the raid controller check if it works
If you get same error now , then its time to replace the raid controller
Thanks
Oct 13, 2010 | IBM x3400 Server
Describe how to update blue ray player
Software Update Instructions
    • WARNING!! Do not power off the Home Entertainment Server or disconnect it from the AC power outlet. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • WARNING!! Do not press any buttons, except as instructed, until the update is complete. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • The software update process usually takes about 15 to 30 minutes, depending on system configuration and network connection.
    1. Power on the television and make sure it is tuned to the inputs to which the HES-V1000 Home Entertainment Server is connected.
    2. Connect the LAN terminal on the HES-V1000 to your Internet source using an Ethernet cable.
    3. Power on the HES-V1000 Home Entertainment Server.
    4. Press "HOME" to go to the Home Menu.
    5. At the "Home" menu, select "Settings".
    6. At the "Settings" menu, select "System Settings" and then press "ENTER".
    7. At the "System Settings" screen, select "Software Update" and then press "ENTER".
    8. At the "Software Update" screen, select "Network Update" and then press "ENTER".
      Note: The network connection display appears.
    9. Select "Yes" and press "ENTER".
      Note: The server starts to check the version information.
    10. At the version confirmation screen, select "Yes" and then press "ENTER".
    11. The software License Agreement appears. After reading the content, select "Agree" and press "ENTER".
    12. The software update is downloaded and automatically starts updating the HES-V1000 software.While the software update is downloading:
      • "DOWNLOADING XX%" appears on the front panel display, indicating the progress.
      • If the download fails, an error message appears on the screen, and the display returns to the Home Menu.
      When the software update is complete:
      • "VERSION UP FINISH" appears on the front panel display, indicating that the update was successful.
      • If "VERSION UP FAIL" appears on the front panel display, repeat the update procedure above.
    13. The system will power off automatically.
    14. Power on the Home Entertainment Server again.
Please refer the following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5321&mdl=HESV1000
Feb 11, 2010 | Sony HESV1000 200 Disc Blue-Ray Server
Dec 09, 2009 | IBM x3400 Server
In ibm x3400 series controller monitor failed what should i do
after bios screen my ibm x3400 series controller monitor failed what should i do
Feb 20, 2009 | IBM x3400 Server
IBM System x3500 7977 - Quad-Core Xeon X5355 2.66 GHz (7977H2U) Server Logo
1,155 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
