Question about Casio Watches
How to set time on a casio modulle no 4723 watch
Had a battery change and cant reset the time
SOURCE: setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Posted on Mar 09, 2008
  • 13433 Answers
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: cant remember how to change (hands) time on casio fishing gear
Push the MODE (down left) bottom six times, you will see in your display HS then push the ADJUST bottom (up left) until your digital time start to flashing then push the SEARCH (down right) bottom the hands time will start to move, once you have set the time you want push the ADJUST bottom (up left) once and push the MODE (down left) once and you done.
Ricardo DeLeon
Posted on Mar 12, 2009
escapement
  • 2334 Answers
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
Rate me, please.
Posted on Mar 15, 2009
escapement
  • 2334 Answers
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Posted on Mar 31, 2009
Coleman watch is on but cant change the time
Try this site:
http://www.ehow.com/how_8204646_set-date-coleman-watch.html
Jan 21, 2013 | Watches
Cant set digital time and date and alarm, downloaded manual but does not work
There is a reset procedure for most LCD watches to reset the LCD after installing the battery. It is different for every watch brand and movement (inner works). I recommend visiting your local Certified Master Horologist for proper battery and resetting procedure.
Improperly resetting any digital watch by shorting the wrong connection can essentially short out the movement, and the movement / watch must then be replaced, whichever is least expensive.
Feb 23, 2011 | Watches
Hello ,,, I changed the battery in my Timex Indiglo and now just the light is working but not the minute hand or time hands. How do I fix this I have tried two batteries already?
Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
Jul 23, 2010 | Timex 27191 Wristwatch
STOP WATCH NOT WORKING
mcdevito75 here, Best Bet, return to the shop that changed the Battery, it may not be the absolute correct battery, Battery could have come slightly loose.
Jul 21, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
I am trying to change the 2016 battery in my Casio AQ 150W. I put the new battery in but no power. On inside of case it says "after battery replacement, contact AC with battery ( ) using...
I have a similar model.  The electronics sometimes needs to be reset after the battery is changes.  Get a magnifying glass and look closely at the stainless frame around the battery.  There is a small AC mark and a triangle which points toward a small gold contact down in an adjacent hole.  This contact must be shorted momentarily to the + side of the battery to reset the display.  You can bend a metal paper clip to make the connection.  You may have to try several times before it resets. It should reset to 12:00 and start running.
Jul 11, 2008 | Casio Watches
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
Sportline watch
Love my watch, Was placing it on wrist, time correct, pressed button to test pulse and everything went blank. Pressed reset button, with no effect. It has a high pitched whine when placed at ear.
Does this mean I need a new battery, and where is that done, so I don't mess it up.
Appreciate any help as I don't have the instruction book either,
Scotty
Feb 22, 2008 | Sportline 1000 Memory watch
Error Code Display
Mine did the same thing after changing the battery and would reset intermittently without warning. For some unknown reason I decided to open the watch again. This time I reset the time and date with the back off the watch while deprssing the small spring that is there on the inside . Haven't had a problem since. Don't know if this is the solution but it worked for me. Good luck!
Les H.
Oct 30, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Watches Logo
165 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
