Question about Sta Rite Pool & Spa
Sta-rite 3/4 hp C48J2EC15 PUMP MODEL SND-L IS GETTING INCREASINGLY LOUDER WHEN KICKS ON, BEARINGS OR???
SEEMS TO BE LOSING PRESSURE AND MAKES MORE AND MORE NOISE WHEN RUNNING
    Top Expert:
  • Sta Rite Master
  • 5,922 Answers
Bearings overheating motor and seals melting replace whole pump
Posted on May 19, 2016
  • 61 Answers
SOURCE: PRESSURE RUNNING TOO HIGH
Most filters are rated to 50 psi..although 35 does seem high. make sure that all of your returns are open..could be a valve, or have some other kind of blockage. Although rare, check valves can get stuck closed, so check them, too.. If you have a white one that is solid get rid of it and get one that you can see into..jandy for instance...
Just as a rule I always install a bypass on any heater or heatpump. It will increace the life of the heat exchanger by years.......
Posted on Apr 05, 2009
john224
  • 1378 Answers
SOURCE: Water runs out waste line when pump is running. we
If you already replaced the gasket and upon opeing the valve, it is still in the grooves, look for a crack in the valve body and/or diffuser.
Posted on Jun 19, 2009
smartr10U
  • 1305 Answers
SOURCE: Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Posted on Jun 03, 2010
Testimonial: "Thank you very much I will give it a try. I know this will stop the debris for sure. Again thanks"
tweedleedee0
  • 15 Answers
SOURCE: I have a sta rite pool filtere and it is running
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric2_bing.gif motor repair shop for an inspection.
Posted on Jun 27, 2010
MOTORWIZJ
  • 1358 Answers
SOURCE: I have a Sta-Rite Dura Glas 3/4 HP that when
most of the time its the start capacitor or a dirty start switch. the start switch can be cleaned with the striker off a match book use CARE not to bend the switch , the switch is in contact when motor is starting and open when running... look for free pool pump motor testing in you area and see if they can test the cap for ya as it requires a special meter to do THE TEST RIGHT ! and you might need a shaft seal when all is done. good luck// jay the pool pump repair guy FLORIDA
Posted on Sep 30, 2010
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Is there a trik to getting it together enough to get the ring on
when i have to get into the lid on my pump i make sure the pump is on. when the pump is on it is sucking 'down' on the lid and therefore making it easier to remove. Once the pump is off, the pressure from the water in the pool pushes up the lid and makes it almost impossible to remove.
US Parts Center
Aug 21, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I have a sta rite model # p2ra5f182L. The pump is about 6 yrs old and sounds like the bearings are getting ready to go. Can I replace the motor or should I replace the the whole unit?
this is the best pump out there. ya fix it !look for your local pool pump repair guy and have him do a bearing job on it about 75.00.. i love these pumps. when you pick up your pump ask him how to take better care of it..... jay longwood florida
Jan 29, 2011 | Sta Rite StaRite Duraglas Pump 1 12 HP...
Procedure to change electric motor on sta rite pump
better off to replace whole pump if motor overheating seals going bad too if leaking soon bad bearings
Jan 16, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I have a STA RITE 1 hp above ground pump that is used for my lawn irrigation system. It is about 3 years old. It seems to be making more "noise" as it runs than it has before... Q. Is there a way to...
Hi Tom, The reason your pump is getting noisy is because the motor bearings are worn out. This can also be caused if the shaft seal between the motor and the wet end is leaking. The bearings can't be lubricated because they are sealed. The best solution is to have the bearings replaced as well as a complete seal kit for the wet end.
Oct 17, 2010 | Sta Rite 1 Hp Above Ground Pump Ne641
I have a sta rite abg series pool pump, u can see my pump at this link: http://www.poolpartsonline.com/p-59481-sta-rite-abg-series-pool-pump-parts.aspx My motor is making a high pitched sound and i was...
It will be better to service the machine the machine than to change the bearing.
Servicing the machine will stop the high pitch sound and makes it work better and also reduce your cost.
Thanks for contacting Fixya.
Jun 30, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Reset button for sta-rite well pump kicks off
That could be a bad wire in the well or the pump motor has a flat spot...or a spot that if the motor stops there it will not start....also could be that the pump bearings are worn and the motor locks up once in a while...
Bottom line the pump will need to be pulled and probably replaced....
http://www.fixya.com/support/r3755320-electric_problems_submersible_pumps
heatman101
Apr 22, 2010 | Plumbing
Pool & Spa Logo
292 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
