Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Rebel T2i won't power on
This camera will not turn on. Bought new battery still not working. Only 2 years old. Help!
I had this problem and thank you to the gent that suggested there was a battery compartment closing detection mechanism. I have a battery grip and had removed that to register my t2i (needed the serial number on the bottom) and never checked operation after replacing. I toyed with the lever using a pen and noticed the red light flicker. I replaced the battery grip with batteries and all is well.
Sometimes we need a nudge to dig deeper... I had looked at the possibility of a door closed switch much the same as the the switch on the sd card door. I took a second look and found it. Thanks a million for jogging my analytical brain!
Posted on Jan 18, 2014
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
Posted on Feb 07, 2009
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
SOURCE: Cannon Digital Rebel xt died will not turn on , recharged nothing
I think you have a faulty fuse (there are three in total) inside the camera. The fuse might have blown because of bent pin for the memory cards or a faulty cf card. In wich case, you have to repair it yourself, there are pages on the web that describe what you have to do (search for fuse and 350d), or send it to a canon service center ( they will change the complete motherboard because the fuses are soldered to the mainboard and they won't change them)
Sorry budddy
Posted on Feb 06, 2009
LongPockets
  • 1177 Answers
SOURCE: I newly bought a Canon
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Posted on Jan 29, 2011
LogicX
  • 93 Answers
SOURCE: My new canon rebel T2i/EOS
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
Posted on Mar 12, 2011
Camera freezes up, screen turns black, red light stays on and I am forced to remove the battery to power it off. My firmware is updated, I re- formatted the memory card, bought a new memory...
What lens are you using? There might be issues with the contacts, therefore - using a dry clean, non abrasive cloth, try wiping the contacts on the lens - as well as the camera body. and see what that does.
Feb 26, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Tip
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
on Jul 13, 2010 | Cameras
My camera won't focus!
While looking through the viewfinder, turn the diopter adjustment knob just above and right of the viewfinder to adjust it until the focus marks and other information in the viewfinder become sharp to your eye.
Aug 21, 2012 | Canon EOS 550D Rebel T2i Digital Camera
I bought canon eos kiss x4, but there is no indonesian manual. where i can get an indonesian manual for my dslr camera?
The Kiss X4 is called the Rebel T2i in some parts of the world. You may download the Rebel T2i manual (and more) from here.
May 27, 2012 | Canon Cameras
Canon EOS 550D won't turn on
If you have Magic Lantern installed on your camera and it won't turn on, all I had to was re-format the SD card. Works perfectly now. You just need to get rid of ML.
Jan 15, 2012 | Canon REBEL T2i EOS 550D Digital Camera...
I recently purchased a Canon EOS Rebel T3i SLR camera (July 2011) and already I am encountering a problem called "Err 05 the built-in flash could not be raised." Does anyone know how to resolve...
Hey Leo,
Unfortunately the problem you've mentioned is quiet common with your particular model.
Here's what Canon recommends, on its website.
-Turn the power switch to < ON > to turn on the power again.
And, if that doesn't work. Buddy, you'll have to drop by a service center. Hurry up, or you'll run out on the warranty period.
Toodles,
Rebel K
Sep 18, 2011 | Canon EOS 550D Rebel T2i Digital Camera
New canon t2i. keep getting error 70. haven't even been able to take a single picture
hello. good day. error 70 is appears when malfunctions related to images have been detected.
try doing the following:
1. power down camera and remove battery
2. power down HDMI device or powered adapter
3. unplug the HDMI from the body, then plug it back in
4. power up HDMI device or powered adapter
5. insert battery and power up camera
hope this helps. is error still appear. try this link for canon support http://www.usa.canon.com/cusa/about_canon?pageKeyCode=50
Apr 29, 2011 | Canon EOS 550D Rebel T2i Digital Camera
I'm new in DSLR camera and I just bought a rebel t2i/canon 550d and I'm here in Japan so all the manuals are written in japanese. Where can I find the same manual in english? tnx in advance!
Try the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=19943
May 04, 2010 | Canon EOS 550D Rebel T2i Digital Camera
EOS Rebel T2i Digital SLR is stuck on Sensor Cleaning
If you bought this camera new, return to the store and get help, or some dealer. You may also call Canon support for this model and get help there. Canon has great support, and will surely help.
Hope it works.
Apr 18, 2010 | Cameras
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
1,433 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
