I need owners manual for moretti elite mypn15c as it won't stay on for over a minute without changing to heat
Moretti heater manual
www.moretti.com.ar/downloads.php?id=132
homeappliance.manualsonline.com > Household Appliance
Jul 03, 2014 | Heating & Cooling
The icons on the lcd of My Moretti Elite mypn15c keeps on blinking and some of the words ccnaot be red anymore. How to solve this uuse? Thanks
HAVE CHECK THE DEVICE MANAGE TO SEE IF THE DRIVERS ARE UP TO DATE. IF SO, THAN CHECK THE PLUG TO THE MONITOR AND TO THE VIDEO CARD., CHECK THE RESOLUTIONS BY RIGHT CLICKING ON THE SCREEN THAN GO DOWN TO SCREEN RESOLUTION OPEN FOLD OR PROGRAM
1. CLICK ON IDENTIFY
IF OKAY THAN LOOK FOR ADVANCE SETTINGS CLICK OR OPEN THE PROGRAM
GO THREW EACH SETTINGS OR SKIP TO TROUBLESHOOTING
FOLLOW INSTRUCTIONS
2. SELECT PROPERTY'S
CHECK DRIVERS.
IF ALL IS OKAY
TWO THINGS MAYBE THE PROBLEM
1 VIDEO CARD OR CARDS MAYBE FAULTY
2. MONITOR IS FAULTY
3. IT MAY BE POWER SUPPLY ISSUE (MAYBE NOT)
THANK YOU ROD
May 30, 2014 | BenQ Computers & Internet
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Jul 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
Heating & Cooling Logo
530 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
