Brother HL-4050CDN Printer Logo
A
Anonymous Posted on Dec 06, 2012
Reset drum HL-4150CDN
How do i reset the drum counter after inmstalling a new drum unit?
5 Related Answers
Anonymous
  • 417 Answers
  • Posted on Feb 04, 2008
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Anonymous
  • 121 Answers
  • Posted on Mar 23, 2009
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Anonymous
  • 107 Answers
  • Posted on Nov 03, 2010
SOURCE: I just replaced the drum
hello, first did you follow instructions of reseting machine when you replaced drum, if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
Anonymous
  • 90 Answers
  • Posted on Aug 03, 2009
SOURCE: Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
mbkilimci
MUSTAFA BULENT KILIMCI
  • 166 Answers
  • Posted on Dec 15, 2009
SOURCE: HOW DO I RESET THE DRUM KIT COUNTER ON A BROTHER
open the door and press clear/back and then press 1
Brother hl-5140 drum light how to fix
If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  • Make sure that the machine is turned on.
  • Open the front cover.
  • To reset the drum counter, press and hold down Go for about 4 seconds until all the LEDs light up.
The Drum LED is still on or flashing after replace the drum unit with new...
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
4helpful
Product is Brother HL-4150CDN laser printer. The LCD display is saying Replace Toner (Back) I have 2 black toner carts available. One that I slightly used previously before swapping it out with a new one...
Had this same problem on the same printer. Here is the solution.
Open the front cover of the printer and press "Cancel" & "Secure". This will access a secret menu that will let you reset the toner counter. There are 12 settings in all (3 per color).
Two thumbs up going out to TonerHacker007 on the fixyourownprinter.com forums for this one.
7helpful
Drum light flashing in spite of new drum unit and new toner cartridge
common problem.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
23helpful
3answers
Hi.
15helpful
How do I reset the Drum counter on a Brother HL-5140?
Caution! Reset the drum counter only when you replace the drum unit with a new one.
To reset the Drum Counter:
1. Press the cover release button and then open the front cover of the printer.
2. Press and hold down the 'Go' button until all four LEDs are lit. Once all four LEDs are lit, release the 'Go' button.
3. Close the front cover. Make sure that the Drum LED is now off.
11helpful
2answers
13helpful
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
1helpful
Beother Hl 2040 printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
17helpful
4answers
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Norman Weimar
Norman Weimar
k24674
