Question about HP LaserJet 2840 All-In-One Printer
50.32.00 fuser error HP LaserJet 600m All-In-One Printer
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
  • 10 Answers
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
Posted on Oct 22, 2008
antiochpc
  • 1314 Answers
SOURCE: 50.3 fuser error
You need to replace the fuser, a consumable item.
Posted on Jun 17, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Problem with HP LaserJet 9050dn Printer 50.1 fuser error
Low fuser temperature detected.
1. Remove & refix the fuser..
2. Replace the fuser...
May 07, 2014 | HP LaserJet 9050dn Printer
Printer error 59.30 HP laserjet 9040dn
This error refers to the fuser or fuser drive motor. Try replace the fuser. If the error remains, try changing the fuser drive motor. That should fix your problem...
May 03, 2012 | HP Laserjet 9040 Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
Mar 25, 2009 | HP Color Laserjet 3550 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 2840 All-In-One Printer Logo
1,778 people viewed this question
Seeker5211
Seeker5211
