Slow leak at fill holes - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 07, 2012
  • jgeile
    jgeile Dec 10, 2012
    my machine is a ge whre5550k1ww , my son did a couple of loads of laundry and the machine is no longer dripping. Not sure if the leak will start up again but at this point it has not. Thanks for your repsonse.
I neeed to know how much oil to fill in the gearbox after I have changed a leaking oil ring.
If the fill hole is on the top, fill it all the way, if the fill hole is on the side, then fill up to the hole
Nov 21, 2015 | Garden
How can I determine why my is my Hurricane Phoenix 120 is leaking?
Inside the scupper holes which can't really be inspected, leaks can be a serious problem. some owner tie a rope thru the scupper holes to attach to a rack or other reason, but when the walls inside the scupper holes 'crack' there's no way to tell. Stand the kayak on end and fill with water. Look for leaks that way, by filling the whole tamale with water and inspect for water leaking out. Probably time to shop for a new one!
Aug 17, 2014 | Hurricane Kayaks Phoenix 120 Sit-On-Top...
Leaking washing machine
Need more information. What type of leak (fast, slow, seep, etc.), when does it leak (when it is filling, draining, all the time, or don't know), and where is the leak coming from? If water runs out as fast as it is filling, you may have a drain hose that is ruptured or has disconnected. If it is a very slow leak, you may have a connection that is working loose. Or, it could be as serious as a hole in the outer drum. Is this a top loader or a front loader washing machine?
Apr 10, 2014 | Maytag Washing Machines
Water is leaking slowing after filling up the tank and water supply is shut off. where is the leak?
In this toilet there is a flapper valve that blocks the hole for the water to transfer from the tank to thebowl. If you fill the tank and water is leaking into the bowl put your hand in the tank and apply alittle pressure to the flapper, the leak should stop. You can buy replacement parts for this toilet at Home depot or Lowes they carry universal lits that are perfect for this issue.
Jun 14, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
Manual transmission fluid leak. Where do I find the fill hole
check passenger side of transmission - it is a 3/8 ext that will fit the bolt - does not really look like a regular fill hole -
Aug 01, 2009 | 2003 Jeep Wrangler
We have a slow leak coming from beneath the pool (the pool is filled with water) the pool is 18 feet diameter by four feet deep. Is there a way to locate the leak and repair it while filled with water? We...
There is a way to locate leaks that are under water using a red dye that should be available at any pool supply store. It should come with directions, but basically you put the dye in the water and it will flow twards the leak and then you know where the crack/hole/leak is located.
Apr 14, 2009 | Sport & Outdoor - Others
Kohler one-piece lowboy..rialto? leaks from suply below tank
I'm assuming based on your post that the leak is outside the toilet near the inlet to the fill valve. Based on 10 years in the business, there shouldn't be holes in or near this place. Have you tried replacing the fill valve? If you go to the hardware store and look at a new fill valve, you will find that there aren't any holes. They aren't expensive, so I would just replace it.
Apr 11, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Oil leaking from front differential hose line
There are to plugs on the passenger side of the center carrier. The top one is the fill plug. Remove this plug and fill to this hole. If you are familiar with filling a rear dif then it is the same method. Please rate or tell me if you need more help.
Dec 25, 2008 | 2007 GMC Sierra 2500HD
Hilux leaking gear oil
There is a plug on the side of the gear box. Pull plug out. You should be able to stick your finger into the hole and touch the gear oil. If not, check on your owner manual and see what type of oil goes back into the gear box. Fill it up until it start coming out of the plug hole.put plug back in, & back to riding.
Are when you go to the oil change shop???? Get them to show you where it is at, and get them to top it off for you.???
Nov 13, 2008 | 1998 Toyota 4Runner
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
