Question about Bunn NHB Coffee Maker
RANCID BUTTER melted in Bunn Thermofresh resevoir vents!
We have the Thermofresh Bunn, with the resevoir of hot water in the back. Across the top part, there are three small ****-type vents.
Stupidly, I sat a pound of frozen butter across the top of the machine while I was doing something... then I forgot about it!
The butter melted and went INTO the vents. What's worse, is that I didn't realize it and made coffee, thereby sending the butter down into the resevoir tank. I have cleaned out all the top parts of the machine but am not sure how to get the resevoir tank out, because of all the wires on the top and the tubing that goes down around the outside of it.
Now the water has a TERRIBLE smell and taste, like rancid butter, and you can't use the maching for anything at all.
Can you tell me how to get to the resevoir to clean that out or do I have to bring it to an authorized dealer? This coffee machine cost nearly $200 and is just over a year old. Obviously, my neglect and subsequent butter melting negates getting this fixed under any warranty.
  • shanandlou Mar 14, 2009
    I set a plate of butter on top of my coffee pot also, and forgot about it. I didnt think it got inside until I made coffee and it had this horrible smell...and taste! I just kept adding pots of water and running it through and pots of water w/vinegar and pots of water w/ CLR. But you have to wait a little while between pots so the water in the resevoir stays hot and keeps the butter melted. it took alot of pots of water and about a week but I think its as good as new now. I was glad to see I wasnt the only "non-thinking" person to let this happen:)
  • Darrell Swisher
    Darrell Swisher Dec 01, 2013
    my wife just did the same thing on thanksgiving day, I have been running vinegar water thru it even some grease busting cleaner....it gets better everytime i do it but still has the taste and smell.....i will just keeping doing it until its all gone....very nasty though.
  • 189 Answers
There is one thing you can try first. With the machine filled with water and turned on, pour in 1 quart of white vinegar and let it sit in there for 2 hours. Then flush it back out with 8-10 carafes of water. If this doesn't correct the problem, then call customer service with the model and code date. This can be replaced under the warranty if it is under 3 years old or less. If it is over 3 years old, it can be replaced at a reduced price.
Posted on May 19, 2010
Why my bunn thermofresh coffee maker makes cold coffee
time for a replacement . they do not sell heating elements
Oct 31, 2016 | Bunn Coffee Makers & Espresso Machines
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn Thermofresh quit heating the water.
The Bun BTX-B has a pair of thermal fuses located on top of the water heater storage unit. If the pot is left without use for a week or so, the thermal fuses will blow if the top of the tank gets too hot (about 150 degrees Fahrenheit) due to the evaporation of water in the storage tank. The operating directions state clearly that if the unit is not going to be used for a few days to turn off the pot. These are there to prevent a fire in case someone does not follow the direction. This is the "MOST" common form of electrical failure in these pots.
To access the thermal fuse
1. Unplug the pot and drain pot by inverting the pot in an empty sink.
2. Remove the two Phillips screws located under the water fill flipper door.
3. Gently insert a small flat blade screw driver into the front top of the lid and remove top cover.
4. Remove the 4 screws inside the water routing tank and remove routing tank simply by lifting off.
5. The thermal fuse is mounted to the top of the tank under a clip and is easily slid out from under the clip. There is a brown wire (goes to power cord neutral) and a black wire (goes into tank disk access hole). Simply measure with a multimeter at lowest ohm setting, the meter should read continuity between the black and brown wires, if it reads an open circuit, the part is bad.
A replacement thermal fuze assembly kit is available off e-bay for about $10. You can buy individual thermal fuzes and replace one of the two that is bad for about $3, but I recommend the kit for most consumers as it comes with wire crimps already mounted and far easier for the average person to simply install. Repair takes about 5-10 minutes.
Mar 03, 2013 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
My Bunn Thermofresh leaks near the top. In the side nd in the back.
If you will call Customer Service with the model and code date on the bottom. If your machine is 3 years old or less, we will replace it free of charge.
Sep 22, 2010 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Butter melted into top and down in to water container
mcdevito75 here, Try to clean your coffee maker by running a decanter full of white vinegar thru the system 2--3 times, then fesh water to rinse out the vinegar. Use a new or clean filter at the beginning of the vinegar treatment and after when you rinse with regular water.
Jul 07, 2010 | Bunn 10 Cup Home Coffee Brewer
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Bunn BT 10B -RANCID BUTTER in Resevoir!
Hi Tina - I'm no expert on melted butter in your coffee maker; but, I'd bet that the butter also got into the internal water tank where the water gets heated. Try going to the Bunn website: www.bunn.com , and click on their Customer Service link. You can either call their toll-free number or write to them with your problem from there.
Hope this helps!
Jan 13, 2009 | Bunn BT10B Coffee Maker
Bunn NHB Coffee Maker Logo
288 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
