Question about Intel Desktop Board DG41WV Motherboard
How to connect power sw in intel dg41wv - Intel Desktop Board DG41WV Motherboard
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Posted on Dec 22, 2007
  • 53 Answers
SOURCE: wires connection
If you know where the board came from i.e. a dell laptop model number or dell desktop model number this would help.
The issue is this is a Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} propretary version of the motherboard and can have different configurations based on what machine you got it from.
This is a link to the Dell Dimesion 8400 spec for that board.
The E210882 is commonly the D865GLC motherboard from intel spec is here.
Posted on Jan 30, 2009
MPetro302
  • 298 Answers
SOURCE: number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
Posted on Apr 18, 2009
Intel dg41wv motherboard dispalay problem
after improper overclocking you can reset the BIOS to default settings and hope that components are not damaged. And do not try overclock again.
Dec 19, 2013 | Intel Essential DG41WV Desktop Motherboard...
Is dg41wv Desktop motherboard match dg41rq for Intel 2Duo core processor?
The DG41WV doesn't support as many processors, but it does support quite a few of the same one as the DG41RQ. Here are 2 links you can use to compare supported processors:
DG41WV Link:
http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DG41WV
DG41RQ Link:
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=DG41RQ
May 17, 2012 | Computers & Internet
Sir, my name is Naresh my system not working. due to mother board not supported.
Hi
Which operating system are you using or do you intend to use?
This page tells you the full specifications of the motherboard and which processors it is compatible with:
http://ark.intel.com/products/48621/Intel-Desktop-Board-DG41WV
This page tells you which operating systems it is compatible with:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+4+Series+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+DG41WV
I hope this helps.
Aug 24, 2011 | Intel Essential DG41WV Desktop Motherboard...
Driver of audio
The drive can be obtained from the manufacturers website
and entering dg41wv in the search
cheers
djbr1ck
May 13, 2011 | Intel Essential DG41WV Desktop Motherboard...
I lost my motherboard (intel dg41wv)'s drivers cd from where can i download the drivers for free
Try here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41WV
If the link doesn't work, go to the intel site, www.intel.com and click on Support >> Drivers and downloads and search for your board.
May 06, 2011 | Intel Essential DG41WV Desktop Motherboard...
How to intall xp intel dg41wv
hi sabu, you have to install XP in your system. Good luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Intel Essential DG41WV Desktop Motherboard...
Intel Desktop Board DG41WV Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
