Question about Kodak EasyShare P850 Digital Camera
P850 I took a series of shots that went fine, then the next one had highly colorized black horizontal lines running through the picture. The lines showed both on the view screen and on the photograph. Weeks later, after putting it in a suitcase to take it to be fixed, it worked fine for a few shots, then the colorized horizontal black lines emerged again. I realized that if, when I held the camera for a shot, I held the left top and bottom between my fingers and squeezed hard, the picture looked fine again. Apparently applying pressure there works temporarily, but then the colorized black horizontal lines appear again. Can anyone help? Sue
My lens on P850 when I turn it on goes out and then goes back in, I have change the battery, can you assist
Posted on Dec 02, 2009
  • 28 Answers
This fix should only be done by a professional or one who is familiar with repairing electronic devices. I have fixed many Kodak camera's with exactly the same problem.
Inside the camera the lens is attached to the circuit board with a ribbon cable and it inserts into a connector that it's latch can pop open if the camera is dropped or Jared. The way to fix it is to remove the back and re snap the connector. I have fixed many this way. There are two hidden screws behind the eye piece. Press down on the eye piece after removing the screws on the bottom. Be very careful where you touch on the circuit board. In the upper right corner is where the high voltage is for the flash. That can cause a nasty shock if you touch it. Even if the battery is removed it holds a charge.
Posted on Oct 10, 2007
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
My camera has been working fine. Had it in my purse over the weekend, took it out to take pictures. When I turned it on, I have this cone shaped image in the middle of the screen that has a red line...
When you take one pic, this lines appears in the image? Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
Among the CCDs used in the affected products listed above, it has been confirmed that, especially under high-temperature/high-humidity environments, the internal wiring may come undone in some places.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Jun 22, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Lcd tv
What is the make and model number of your set? I may b able to help you. desribe in more detail is the picture gone entirely and you only see colored horizontal lines on ablack screen?
Jan 21, 2008 | Televison & Video
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
Jan 19, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
169 people viewed this question
Top Kodak Cameras Experts
Computer Links
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
