Question about Nintendo DS Console
Is it possible to connect to computer? - Nintendo DS Console
    Genius:
  • 1,175 Answers
Http://www.nintendo.com/consumer/systems/selectds.jsp
There should be a manual and anything else youre looking for.
Cheers
Posted on Jan 12, 2009
When i on my desktop it show blue screen and says no signal analog
That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
(who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
Oct 02, 2011 | Computers & Internet
Internet of my computer was work off line,during im cleaning of the dust I remove all the connection bihind,after I finish,I return the connection,then I start th computer and open the internet but it was...
Possible solution to your problem is to rechecked again the connections if it is in right connection or it possible to be loosen so you better to tighten the connector from your pc,may be your router is unplug,check it.If it is already Ok now,check now the connection of internet,by going into the control panel and click network connections,it should be connected,if not select the computer icon and right click your mouse then choose enable,the computer icon should be in light blue color,it means your connected.
May 30, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Why is my screen flashing green
The problem is with either the monitor or the video card. I would start with the monitor. Make sure the VGA cable is securely connected to the computer and to the monitor. If possible, connect that monitor to a different computer to see if the flashing continues. Or if possible, connect a different monitor to your computer to see if you can duplicate the problem. Hope this helps.
Regards,
Matt
Apr 14, 2011 | Acer 19" LCD Monitor
I wont to play game in lan with my home frends bat my computer canot find a lan .the game is full . my net is with dinamic ip..what i can do?thanks
D-link router provides signals through cable wired connection where each persons computer shares signals from the only computer that has network services. For example, one of the computers that has the internet on which router is connected either has capacity to network several additional computers or not. Usually the server computer that has connections with ethernet cables makes sharing signals possible beyond dial up phone line networked cable conections.The routers splits signals between computers requesting connectivity only becomes possible when enough capacity exist to several computers. The type of network strutures makes the link possible. For example, D-link router should allow to network more than one computer else another router that makes signal expansion possible is prefered. Circumpectively, ascertain that the computer from which video game is installed has the expansive capacity either in cables connection ports, wire links where router becomes the location where each device derives resources.
Feb 22, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Cannot recieve faxes more than 2 pages long. Message Communications error 232
The device has a communication malfunction.
possible diagnostics to be performed
1. The communication lines or phone connectivities are malfunct, consider unplugging each modem properly reconnecting taking keen observation of jack areas on the fax machine, and the external areas on the router units splitting the signals.
2. The fax machine paper feed system is clogged possible inspection of the tray areas making sure to unclog stuck paper.
a. The fax machines provides an image measurable in laser signals required to produce results immediately. Any delay in the signals or data when arrives in fax machine could cause incomplete imprint
3. The fax machine could have many messages queue causing delay malfunctions.
a. The type of signal splitter available at the location could cause to delay, where a delay excapes signal recognition on the paper only producing a few data records
important notes
1. consider acquiring a fax consigment at a time
2. consider distributing fax loads to another infrustruction
Error 232 is a connectivity message
1. possibly caused by accidentally unplugging a connection and reconnecting while fax machine was powered on.
2. possibly caused by connecting another fax machine to the set up of infrusture without performing system restore to intergrate all devices connected to the network.
3.possibly also caused by a computer program malfunction.
a. consider reinstalling the programs that connect the fax machine; for example access the computer networking infrusture icons located in the control panel area of the computer programs list bar to perform networking diagnostics for the fax machine
instruction s of performing a fax network reinstallation
1.The networks on the computer housing every additional peripheral device like faxes all share with printers, game consules and several recognisable within the computer server or mainframe computer. A wireless connectivy of several connection compromised the intergrity of some devices.
The response to the problem in computer sending a message with a number to make possible locating the by expert technictians.
2. Several peripherals connected to the computer server produces error messages readable where huge numbers being sysbols of easy problems only on a computer performing several resposnibilties, in which sitaution of faxes, the error 232 could be the number of faxe assigments failures, or number faxes waiting to be completed.
Dec 02, 2010 | Office Equipment & Supplies
How to connect the DSi to the computer
To the computer?! Do you think thats possible? No, absolutely its not possible. You can only connect to the internet.
Dec 01, 2009 | Nintendo DSi White Console
Network or usb cable
Look on the back of the printer. If it's possible, you'll see a USB connector that looks kind of like an arch or doorway. If so, use a USB A to B cable to connect it to your PC. Make sure you use the drivers for a USB connection when reinstalling it.
Jan 14, 2009 | Kyocera Office Equipment & Supplies
No lights
hello!
Is there a computer connected directly to the router? Possible that the router do not detect any physical connection on it. if none of the number light light up it means that there might be no computer directly connected to the router .
Have you tried connecting your computer to a different port? how about using a different cable? How about a different computer? if theres a computer connected to it hardwired but still no light, try to connect your computer to the other ports of the router and check if the lights will come on. if not, try a different cable and a different computer. Possible that t could be a defective port, defective cable, defective lan card or the driver of the lan card on the pc is not properly installed that's why the pc is not detected
Aug 27, 2008 | Belkin (F5D7230-4) Router (587009)
Cable through a computer monitor
Yes it is possible to connect a laptop to a monitor by way of the VGA port on the back or side of the laptop. but unfortunately no you cannot connect cable to the monitor.
Aug 11, 2008 | Denon AVR-886 Receiver
Can usb substitute for the ethernet connection?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
http://search.ebay.com/netdisk
Apr 10, 2008 | Ximeta NetDisk (NOWWL) 160 GB Hard Drive
Nintendo DS Console Logo
15 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
