Question about Sony KDS-55A3000 55" HDTV
Sony kds 55a3000 sound but no picture
Green light blinks for about 10 seconds and then sound comes through with no picture. No error codes or strange sounds. I have tested voltage to ballast (397V) and replaced the bulb. If the ballast is bad I would get an error code of red blinking lights or clicking and buzzing correct? This is really frustrating and any help is greatly appreciated.
  • joshua333
    joshua333 Dec 09, 2012
    I tested the voltage to ballast and it was a few volts low. 395-397V Would this cause the no picture problem? The bulb is a brand new phillips. No error lights or sounds is making it hard to diagnose. Someone please help. Thanks
  • joshua333
    joshua333 Dec 25, 2012
    Well,, maybe? Brand new Phillips bulb from reputable supplier. I can see why you would say that considering no error code, noise or other indication of problem. Sound with no picture would indicate bulb or ballast right? Bulb or ballast problems would result in an error code right? I'll put the bulb in another TV to test it and let you know. Thanks
    Top Expert:
  • Sony Master
  • 14,553 Answers
I hate to say it but maybe the new lamp is bad.
Posted on Dec 23, 2012
3 Suggested Answers
  • 4090 Answers
SOURCE: i have a sony projection tv kds-55a3000 the green
Straightv from the SONY service manual
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • This is not DIY stuff and is dangerous to play around with. I suggest you get a tech to fix it rather than opening it up and doing it yourself. Also dont keep turning it on in the hope it will start. It is more likely to start a fire if it begins to overheat from being constantly started and left plugged in.UNPLUG it
    Please rate my help++++Thanks for using FIXYA
    Posted on May 07, 2010
    SOURCE: Sony SXRD KDS-50A2000 Will not power on. Green
    I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
    Posted on May 11, 2010
    On model#Sony Bravia RDL46SL140 when you turn tv on green on light comes on for a few seconds then red light comes on and blinks. no picture or sound.
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
    Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
    Jul 17, 2014 | Sony BRAVIA Televison & Video
    KDS-R60XBR2 No picture, no sound but solid green light
    These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
    Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
    Sony kds-50a2000 picture blacks out and green light blinks
    Either the lamp is on it's way out or..... the lamp is incompatible because it is not a original one. (ie the same as what they fit in the sony factory)
    Nov 06, 2013 | Sony KDS-50A2000 50" HDTV
    Mitsubishi ws65713 picture goes out
    I know these sets well, you lose brightness but still have sound?
    If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
    UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
    PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
    Watch for power light to blink in a sequence:
    1 blink-then 2 blinks-------no error
    2 blink-then 1 blink-------X-ray protection
    2 blink-then 2 blink-------SHORT PROTECTION*******
    2 blink-then 3 blink---------deflection circuit problem
    2 blink-then 4 blink---------vertical circuit problem
    ******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
    SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
    IF IT IS 2 AND THEN 2---USUALLY
    CONVERGENCE CIRCUIT PROBLEM
    let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
    Nov 02, 2012 | Mitsubishi Televison & Video
    Problem with Sony KDS-60A2000 60
    Hello
    The power supply regulator board has the fault. There ie no repair to this board. You have to replace it as card basis.
    This is the picture of the said power supply board to your Sony TV.2_5_2012_4_35_40_am.jpg
    Feb 05, 2012 | Sony KDS-60A2000 60" HDTV
    Green power light blinks, and TV comes on, and goes out, and power light goes red
    Sounds like a problem with the power supply. After it shuts off do any other lights blink, apart from power LED turning red? Please provide this info as it is a self-diagnostic code that will help identify the problem.
    Sep 16, 2011 | Sony KDS-55A3000 55" HDTV
    Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
    It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
    1800-222-SONY
    I hope this help,
    Skyassoc
    Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
    Power button goes from green to red then lamp button blinks no picture or sound
    Lamp in tv is dead and need to be replaced to get tv back in action.
    Lamp replacement procedure is easy and would be written in user manual.
    Please buy Sony original lamp to get bright picture in tv.
    Thanks.
    Jul 08, 2010 | Sony KDS-55A3000 55" HDTV
    Error codes. no picture or sound after turning
    When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
    May 15, 2010 | Panasonic Televison & Video
    Maganavox flat screen tv no pic, red light blink codes...
    Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
    Mar 25, 2017 | Televison & Video
    Open Questions:
    Sony KDS-55A3000 55" HDTV Logo
    106 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
