Question about Dryers
I have an LG dbe3777w dryer. I've tested all the
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Have you also tested the element?
Posted on Dec 07, 2012
  • Jim St Dec 07, 2012
    Yes.
  • Richard Roth
    Richard Roth Dec 07, 2012
    The moisture sensor should only work on the auto dry cycle. It doesn't heat on the timed dry cycle?
SOURCE: Fisher & Paykel DE08 Dryer sensor
My guess is your PC Board (PCB) is shot and needs to be replaced. From the manual: The PCB measures moisture across the sensing bars on the front duct assemby (it is possible, but unlikely that the sensing bars have lint over them which may be causing a problem). As the clothes slide past the bars the PCB reads the current across the bars. When the clothes are dry the current ceases so the PCB advances the timer. There should be a min of 1 M ohm across the bars when dry. The resistance should be lower when mositure tracks across the bars. To test the bars check the resistance when dry, then wet your finger and place it across the bars and check for resistance. Again...it is very unlikely the bars are the problem. More likely it is the PCB. Part Number WE1M418 for the DE09 (similar to the DE08, but check to make sure with your local appliance parts person). How to replace the PCB: Open the console; unscrew and remove the PCB cover; disconnect the PCB connector; unclip PCB from its holding clips. Reassembly is the reverse procedure. NOTE: The PCB is NOT, repeat NOT, the timer!! It is located on the inside of the console on the left hand side of the instrument cluster
Posted on Mar 07, 2009
Krazytech
  • 725 Answers
SOURCE: Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Posted on Aug 27, 2007
Illeagle
  • 525 Answers
SOURCE: The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Posted on Aug 24, 2009
tbirdfan1
  • 3051 Answers
SOURCE: GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Posted on Jan 23, 2010
  • 464 Answers
SOURCE: my dryer heats, but does not dry the clothes. I
Sounds like you have a blockage in the venting from the dryer to the outside and the moisture from clothes is probably not exiting the dryer and causing the display panel to condensate. Take the vent off the back and dry a load with it off and see what happens.
Posted on Jan 26, 2010
Testimonial: "yep! Had to go under the house and disconnect all the venting and that's where it was! Thanks!"
I have a electric dryer LG DLE0442W WON'T HEAT UP BLOWS OUT COLD AIR
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 28, 2015 | LG Dryers
Will broken moisture sensor cause dryer not to heat
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Aug 18, 2014 | Maytag Dryers
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Where is the sensor located on a lg tromm elect dryer
The moisture sensor is located in front grill area inside the dryer. If you look inside the drum where the filter screen mesh is, you will find 2 curved metal bars. Those are your moisture sensors.
Hope this helps.
Nov 06, 2011 | LG DLE5977 Electric Dryer
Timer not working does not stop automatically
Hello, This is going to be a problem with either the moisture sensor which is the metal strips inside the back rear of the tub or the running thermostat which is normally located on the exhaust vent right near the blower. Try cleaning the moisture sensor first. To test this problem set the dryer for a timed dry for 30 minutes. If the dryer stops the above is your problem. If you have any other questions please feel free to comment again. Good Luck!! Mike
Oct 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
