Question about Royal Office Equipment & Supplies
Royal 9 x cross cut shredder wont go through even two pages thick
This thing stops when paper thicknes enters the machine two pages or more. We have to go reverse forward, reverse, forward until the paper finally works it's ay through. We now have to actually feed one sheet at a time, or the machine jams.
    Genius:
  • 1,218 Answers
Put some shredder oil on the paper you are shreding...shred a number of sheets with oil on them so that the oil gets down into the cutting shafts/teeth.
Posted on Aug 22, 2010
Royal mc100mx
Dear Michael,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Mar 21, 2014 | Royal 29140X PX100MX Cross-Cut Shredder
ROYAL 150 MX WILL ONLY TAKE 2 SHEETS
Have you ever "oiled" the machine.
ALL cross-cut shredders need to be oiled to help clear out the paper dust and debris generated during the shredding process.
Pour some shredder oil across the cutting shafts while it is running and occassionaly put some oil onto a sheet of paper as you shred it.
May 09, 2011 | Royal 150MX Cross-Cut Shredder
Every time we insert paper, even one sheet, it goes to overload. We cleaned out all paper from inside and its still doing it.
Have you ever oiled the cutting shafts....all cross-cut shredders require some amount of lubrication....the more you use it the more it should be lubricated. You can get a bottle of lightweight shredder oil from the same place you got the machine.
Feb 13, 2011 | Royal VF1012mx Shredder
Have you ever oiled the machine...its a cross cut shredder and you are supposed to regularly lubricate the cuttting shafts with shredder oil.
Feb 08, 2011 | Royal VF1012mx Shredder
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
When we put paper in our shredder, even just 1 sheet, it sounds real sluggish like it's losing power, then it almost shuts off and the trouble light comes. It's plugged in. Is there a fuse or something...
Have you ever oiled the machine.?????
Cross cut shredders need to be lubricated due to the amounts of small paper and dust generated.
Get some "shredder oil" run the machine in reverse and pour some of the oil onto the cutting blades...then when you shred paper put some oil onto a sheet of paper prior to putting it in the shredder. How often do you oil it??? depends how much shredding you do.
Nov 20, 2010 | Royal 1280MX Shredder
BLADES LOCK UP/JAM ON ROYAL 9X HEAVY DUTY CROSS CUT PAPER SHREDDER.
Have you "oiled" the machine.... put some shredder oil on a piece of paper and shred it....do this a few times to get oil into the cutting blades and see if that helps.
Jan 18, 2010 | Royal Office Equipment & Supplies
Royal vf700 paper shredder wont turn on
If it wont run forward or backwards then probably the pcb inside is fried...call Royal at 1-800-524-0799 for parts assistance.
Jan 05, 2010 | Royal VF700 Cross-Cut Shredder
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
Royal 150MX shredder won't auto shut off. When powered on, always runs until powered off, even after all paper is shredded. Is this also a reset problem or something fouling a switch?
Prob could be the "eyes" in the middle where you put the paper in. They just might need cleaning with a soft cloth( unplug machine first.) If that dos'nt fix it the eyes could be faulty or the pcb could be faulty....give Royal a call at 1-800-524-0799 for parts and prices.
Mar 07, 2009 | Royal 150MX Cross-Cut Shredder
224 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
