Question about InFocus LP70+ Multimedia Projector
Cannot see computer displyed on output of infocus screen shot
The LP70+ unit runs fine and will shoe the default "infocus" screen shot on the viewing wall but when i connect it to the computer i cannot get the LP70 to view the computers output, i have tried other computers - same result
  • 231 Answers
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Posted on Jan 24, 2009
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
I cant get the infocus lp70 to display whats on my computer. i have it connected to my computer.
Look on your keyboard for a dual display symbol (looks like 2 monitors) usually hit Function (F8) and that will cycle you thru the output options that the computer can do.... Good luck and have a great day.... Sincerely HDTV GURU JAY
Mar 17, 2011 | Computers & Internet
I cant get an image from the macbook pro onto the screen using my infocus lp70...help!!!
hi
check your input with remote control(key-menu)
there is different input that you have to select the one you connected in (RGB- analog- digital)
Jul 29, 2010 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
PAL support
Yes the LP70 and the LP70+ both operate perfectly with a PAL source. Also the will operate just fine using 220vac 50hz too.
Cheers
May 31, 2008 | InFocus LP 70 Multimedia Projector
Lp70 projector Error message about Fans
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
Jul 18, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
189 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
