Question about Toys
Need exploded view of cat V80E forklift
I need an exploded view of the front diff/axle & brake system.
  • 373 Answers
SOURCE: front axle how to remove half shaft
Hi.. The step to remove the front Axles of you Vitara.
Raise and support Vehicle . Remove front wheel,
Drain Diff,fluid,
Remove Locking Hub if is equipaded,
Remove Circle clip from axle shaft
On right side of Vehicle, Remove the Stabilizer Little ball joint nut. Remove castle nut Front Tie rod end,
Remove mounting bolts from brake calipper,
Remove Calipper from steering knuckle and wire a side.
Remove Stud Nut from steering knuckle,
Support Lower suspension arm with a jack,
Remove lower strut bracket bolt ,
Lower jack and disconnect Knuckle from lower suspension crontrol arm,
Pull Outler joint from Hub.
Use Large screwdriver or Prybar To pry Right inner joint from differential, The axle will go out making a little froce with the prybar,
To remove the left side,
Remove mounting bolt from inner joint flange,
Pull out axle from hub.
To reinstall just reverse the prosses.
I hope this help on your job...
Thank you for use fixya....
Posted on Aug 19, 2008
BigBlue77
  • 59 Answers
SOURCE: 2005 Yukon Front Diff Axle seals
You don't have to remove the whole diff to change the seals, but you will have to seperate it where the shaft meets the carrier housing. There is a clip holding the passenger axle shaft in place that you have to remove to change the seal. The drivers side axle stub can be removed with a little force as there is a spring clip holding that side in.
Posted on Sep 06, 2008
voodoomox
  • 1689 Answers
SOURCE: replace front wheel bearings
hi emelinabarne
the link below is the parts catalogue for your bike. page 47 and 48 includes an EXPLODED view of the front wheel assembly. actually of all the parts.
http://www.yamaha-motor.com.mx/Manual_Partes/Catalogos/Deportivas%20(Crucero)/XVS1100%20V%20Star/5YS8_2005.PDF
hope this helps you out buddy.
regards,
voodoo
Posted on May 04, 2009
heavymetal77
  • 721 Answers
SOURCE: how does the right front axle come out of a 2005
Yes there's a circlip on the inside.
Posted on Jul 13, 2009
  • 144 Answers
SOURCE: 1990 chevy blazer 4x4 full size,,would like a
Posted on Sep 12, 2009
Testimonial: "thanks for the diagram.. very helpful in replacing my front hub assemblies..."
Timing on a 4y motor toyota forklift
images for Timing on a 4y motor toyota forklift
Timing Chain And Sprockets, Cover And Seal - AutoZone
www.autozone.com/.../Toyota.../Engine.../Timing.../_/P-0900c...
AutoZoneToyota Cressida and Van 1983-1990. REMOVAL & ... 1 Exploded view of the timingcover assembly-3Y-EC and 4Y-EC engines. Click image to see an enlarged ...
How do you set the timing for a toyota 4y engine - Fixya
www.fixya.com/cars/t9616067-set_timing_toyota_4y_engine
Jun 29, 2011 - Posted on Jun 29, 2011.
Nov 07, 2015 | Toyota Cars & Trucks
HOW DO I CHANGE THE REAR WHEEL BEARINGS IN A 1993 JEEP GRAND CHEROKEE LARADO?
no they are bad, unless its brakes
a real mech , checks both.
its one or the other, or worse. bad axle gear/bearings/
the fsm covers both. ever seen the real book? on this car.
the ZJ book is here and free
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
posted like 100+ times, now......
keep in mind jeeps may have different axles.
2wd, 4wd, and locking axles (options)
models 30, 35 and 44 so the details vary that is why the book wins here. the real book wins.
diagnosis is an other matter, i have an electronic stethoscope
that allows me to drive and hear each bearing. cost me $35.
id inspect brakes first. after all they are in clear easy view.
make sure the brake parts are not seized. that includes
the Emg. brake parts !!!
does you car have ABS brakes?
some have drums others have rear disc brakes, the linked FSM
covers both.
for example disc calipers can fail in many ways
guides seized.
pistion seized
emg brake part stuck.
cracked rotors, or warped.
so that be first a real brake inspection on side that makes noise.
if the brakes are ok, then axle bearings are checked next
if you feel radial play they are BAD.
and more. ask.
May 01, 2015 | Jeep Grand Cherokee Cars & Trucks
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
Dec 21, 2010 | Volkswagen Golf Cars & Trucks
How to get the half shaft out
Halfshaft -sorry but the diagrams didn't paste into the fixya.com window, just the text. Also, this was for a 3.2L engine.
REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Front wheel
    • Radiator skid plate
    • Transfer case skid plate
    • Brake calipers and mounting bracket
    • Brake rotor
    • Wheel speed sensor
    • Steering knuckle
  3. Support the axle housing with a jack. Unbolt the axle mounting bracket and
    remove the halfshaft/bracket assembly.
    To install:
  4. Install or connect the following:
    • Axle/bracket assembly. Tighten the bracket flange bolts to 85 ft. lbs. (116
      Nm) and the bracket mounting bolts to 112 ft. lbs. (152 Nm).
    • Steering knuckle
    • Brake rotor
    • Brake caliper and mounting bracket. Tighten the bracket bolts to 115 ft.
      lbs. (155 Nm).
    • Transfer case skid plate. Tighten the bolts to 27 ft. lbs. (37 Nm).
    • Radiator skid plate. Tighten the bolts to 58 ft. lbs. (78 Nm).
    • Front wheel
  5. Check the wheel alignment and adjust as necessary.
    Fig. 1: Exploded view of the left halfshaft, axle shaft and
    axle disconnect
    Fig. 2: Exploded view of the right halfshaft and mounting
    bracket
Oct 31, 2010 | 2002 Isuzu Rodeo Sport
I need to add 80-90W oil in my rear diff, however, I can't seem to find the plug to pull to add in said oil. can anyone help? What am i missing?
Axle Housing Assembly Removal & Installation To Remove:
  1. Raise and support the rear of the vehicle safely using jackstands under the frame. Position a floor jack or a second set of jackstands to support the rear axle housing. If a floor jack is being used, take care when removing the U-bolts to keep the axle from suddenly dislodging.
  2. Remove the rear wheels and drums for clearance and to remove some weight from the axle housing.
  3. If equipped, remove the axle vibration dampener.
  4. Matchmark and remove the rear driveshaft from the pinion flange. Either remove the shaft completely from the vehicle or support it aside from the undercarriage using safety wire, but DO NOT allow the shaft to hang from the slip joint.
  5. Remove the shock absorber-to-axle housing retainers, then swing the shock absorbers away from the axle housing.
  6. Disconnect the brake lines from the axle housing clips and the backing plates (wheel cylinders). NOTE: When disconnecting the brake lines from the wheel cylinders, immediately plug or cap the lines to prevent system contamination or excessive fluid loss.
  7. If applicable, unplug the speed sensor connectors at the junction block.
  8. Disconnect the parking brake cable(s).
  9. Disconnect the axle housing-to-spring U-bolt nuts, washers. U-bolts and the anchor plates.
  10. Remove the vent hose from the top of the axle housing.
  11. Remove the axle with the help of an assistant by moving it to clear the leaf spring, or if desired, the leaf springs can be disconnected from the frame at the rear end to lower the axle down and back, but first refer to the leaf spring procedures for information regarding spring installation and removal.
To Install:
  1. With the help of an assistant, carefully position the rear axle into the vehicle.
  2. Connect the vent hose to the axle housing.
  3. Be sure the housing is properly positioned on the leaf spring, then loosely install the U-bolts, anchor plates, washers and nuts.
    • Tighten the U-bolt nuts in a cross pattern to 18 ft. lbs. (25 Nm) to make sure everything is evenly seated. Then tighten the nuts in steps to 41 ft. lbs. (55 Nm) on 1994-95 models or 74 ft. lbs. (100 Nm) on 1996 and later models.
  4. Remove the caps from the brakes lines then connect the lines and secure them to the axle housing.
  5. If removed, connect the parking brake cable(s).
  6. If applicable, attach the speed sensor connectors to the junction block.
  7. Align and install the driveshaft assembly. Refer to the procedure earlier in this section for details.
  8. Install the shock absorbers to the lower mounts, then tighten the mount nuts.
  9. If equipped, install the axle vibration dampener.
  10. Install the brake drums and the tire/wheel assemblies.
  11. Properly refill the brake master cylinder and bleed the hydraulic brake system.
  12. Check the fluid level in the rear axle assembly and add, as necessary. Make sure the vehicle is level when checking and adding fluid.
  13. Remove the jackstands and carefully lower the truck.
Sep 09, 2010 | 2000 Chevrolet Blazer
Need an exploded diagram of a te20 rear axle
I have a model to 30 tractor.The rear lugs to hold the tire rim need to be replaced,How hard is it to replace and do I take the
whole assembly apart to replace lugs
Jan 31, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Replace front differential and front brakes
a general answer. i dont have the entire procedure in front of me. the best way to do this is to get a shop manual from an auto parts store. it'll explain steb by step, with pictures, the procedure for this repair. the front diff is mounted to the oil pan section of the engine. take off the driver's side axle nut while the truck is still on the ground. then you've got to pull the front tires off, disconnect the upper ball joints, unseat the right side axle out of the diff by hitting it away from the diff where it goes into the engine. then disconnect the left outer tie rod, and pull the left axle out of the truck. take out the front driveshaft from the transfer case to the diff, and drain the front diff. then unbolt it and struggle to get it out of the truck.
Jan 01, 2010 | 2004 Chevrolet TrailBlazer
How do I seperate the front differential from the oil pan...both axles have been removed 2003 Trailblazer 4.2
this is an exploded view of the diff assembly. i'm not sure if it'll help you or not. good luck!
http://www.compnine.com/largeimg/010820TT06-103.gif
Dec 12, 2009 | 2003 Chevrolet Trailblazer Ext
Diff. Fluids for front & rear?
75w140 syn in both axles and 1 small bottle of additive per 1 liter of gear oil for rear axle
Aug 09, 2009 | 2005 Dodge Ram 3500
No brake pressure Cat t50d forklift.
thottle linkage on t50d catipiller forklift anyone know how it goes on
Mar 25, 2009 | Caterpillar American Construction...
Toys Logo
52 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
