Question about Ovens
Westinghouse POL667s oven changing thermostat
2 Suggested Answers
  • 289 Answers
SOURCE: I am trying to install
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Posted on Nov 30, 2010
Change a light globe in the bottom oven of a westinghouse PDR790?
Hi, I think this will help you...
WESTINGHOUSE PDL790W Oven download manual for free now ...
https://www.u-manual.com > Manuals > Brands > WESTINGHOUSE > Oven
May 07, 2017 | Ovens
Westinghouse px 650 gas wall oven wont re ignite once initial heat is met
what you should be doing next is to get a gas fitter out to determine why the pilot light is going out or the sparker is not lighting the gas
gas is not a diy operation as a mistake from you could destroy the building and yourself
Dec 15, 2016 | Ovens
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
Westinghouse oven 688 my oven wont turn off
Sounds like something has happened to your on/off switch that has caused contacts inside to stick in the on position. You will probably have to have it replaced.
Dec 04, 2013 | Ovens
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Jan 23, 2011 | Ovens
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
Nov 30, 2010 | Ovens
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
Oven Not Heating Up
the control panel, has a relay that controls the heating in the oven, it's not closing ther circuit. the electronic timer/control panel, has to be replaced
Apr 21, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
